Results 1 to 5 of 5
Thread: Steering column bush
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Steering column bush
    I replaced my upper steering column ball bearing bush becuase I was able to move the steering wheel up and down maybe 1/4 inch. It still does it. Is there any other bushes in the upper shaft that can be replaced? This genuine part cost me $18 from Holden.
    Can you guys check your VKs if the steering wheel can move like mine? I don't think it's normal.
    Thanks.
    VS Stato SII L67 S/C V6
    Apr 2004
    yep, mine does it, never bothered fixing it
    theres also a big rubber bush at the bottom you have to change
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by haloeight
    Have you got a VK or a VS?
    Apr 2004
    Apr 2004
    the bush is at the bottom of the collapsible caging, where it goes into the floor
  1. Steering column (with a twist)
    By stockhorse in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2007, 10:29 PM
  2. Steering column issue
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2006, 05:17 PM
  3. vr steering column
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2006, 06:47 PM
  4. Steering column adjuster
    By Roh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2006, 02:34 PM
  5. VR Adjustable steering column
    By Scholtzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2005, 11:45 AM
