Results 1 to 6 of 6
Thread: Tripmetre and Odometre on and off?
    1994 VR Exec, 5.0L BT1
    Jan 2005
    Default Tripmetre and Odometre on and off?
    Hey, I've got a VH commodore SL/X. Sometimes the trip metre and odometre work and sometimes they don't. Example, it worked for 2 days then stopped then worked for half a day and has now stopped again. I figured it may be a lose connection somewhere, so I took the cover off the instrument panel and removed the speedo only to find no wires behind it, just a metal rod thing that the speedo sort of connects to. So my question is, where can I find the connections for the trip/odometre that could be loose? Any wires or anything?
    Thanks in advance -SPD.
    VY Calais, WHII Statesman V8, VC L 202
    Feb 2004
    SE Melbourne
    DenchY is offline project status = ongoing
    86' VL 323ci
    Mar 2005
    Newcastle
    it would be the metal cog on that rod thats sliping.. use some good old "heat proof" supergloe and it should be fine..
    Jan 2005
    Okay, I have confirmed that it IS the metal cog that's slipping. It says here 'Speedo Help' that I need to remove the face to glue this wheel. That would mean the needle must be removed. I don't know how to do that and it says it's a bugger to replace. I can't see how I would superglue that wheel anyway. Any tips? I don't wanna break the speedo aswell.
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    Quote Originally Posted by DenchY
    Damm straight, thanx all for advice but it was the metal cog that was slipping on its drive, superglue to the rescue!!! works a treat.
    86' VL 323ci
    Mar 2005
    Newcastle
    remove the white cog, and pull the rod out.. i havent had to glue the metal cog but it does look tricky.. :| i only had to glue the white one back on.
    but yea if u have to pull the white one off, dont forget to glue it back on!
  1. VN Odometre problem
    By h0Ld3n`VN in forum Electrical Wiring / Questions
    Last Post: 06-12-2007, 11:10 PM
  2. this is weird...odometre stoped working but..
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2007, 08:56 PM
