hi basicly i got a auto vh 202 blue motor it has a webber and a 21/4 exhaust on it (no extractors ...yet) and i like the auto as i live around brisbane basicly i got a top speed of around 170ish and im wanting to change the diff ratio's im after a little more rev down low but i dnt want to sacrifice too much top end
just wondering what people are running and suggest to run
thanks in advance
hamish
Personally I wouldn't go lower than 3.36:1... if you still want some top end...
I had that ratio behind a 4spd 202 Torrie !
It was a noticable difference compared to 3.08:1
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
3.45:1 VL diff will give a bit more pickup check my site for my gear ratio chart which will give you speeds at certain RPM.
You need to look at the gearing for 1:1 for the gearbox ratio which means my 4th gear as thats what 3rd is in the traumatic.
cheers
Scott
kewl thanks for the info
what about a 4speed auto ? will the newer commy ones bolt up
