Results 1 to 4 of 4
Thread: want 2 swap dizzy n change 2 carby on VK EFI??
    Apr 2005
    Default want 2 swap dizzy n change 2 carby on VK EFI??
    Hey guys
    may b getting a VK EFI Berlina sedan on gas on the cheap but apparently runs like a pig.(may not even b able 2 keep running. Apparently the fuel line was kinked so it ran gas only(the metal part, not a rubber hose:my: ), but since then its bin running like a bucket.It also had a full tank of petty and lost it over night. jst wondering if;
    1/ any had any idea on the cause, and
    2/ if I replace the dizzy with a Blue(do I even have 2?) and also if I remove the EFI temporarily(may have blocked/gummed up injectors) whats involved in changing 2 the Varijet/inlet manifold??(apparently had them in fuel for a period of time, dunno how long, n it ran fine 4 all of 5 minutes, then went back 2 carp.
    Any suggestions??
    to add insult to injury the batteries flat too(gr8!)
    I'd put it on a trailer n drag it home but the SS is outta rego.Gotta get it running then n there...
    bommodore Guest
    i suggest you get someone to tow it for you and when you get it home pull the crank out and send it to me thanks
    Apr 2005
    bommodore Guest
    no im not greedy but thanks for the offer
  1. Carby swap on VC 3.3ltr.
    By AitchEBoy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-12-2007, 10:06 PM
  2. Replies: 2
    Last Post: 27-09-2006, 11:29 PM
  3. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
  4. VK 308 EFI Dizzy into Carby motor
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-02-2006, 08:53 AM
  5. Vk 202 Carby To Injected Swap
    By oakleydude in forum General
    Last Post: 17-03-2004, 11:33 PM
