Results 1 to 5 of 5
Thread: Fanbelt Troubles.
    1994 VR Exec, 5.0L BT1
    Jan 2005
    Default Fanbelt Troubles.
    My VH is making a sound in the morning that sounds as though the fanbelt is loose. However after about 10min. the sound goes away and is not heard again untill the next morning when I first start it again. Sometimes if I first start it in the afternoon it makes the sound alos, but that is rare. Any ideas as to what may be causing the problem and how to fix it? It's a blue 202, 3.3L straight 6.
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    It could be a bit of oil or grease on it. It might need adjusting. The belts should have about 7-9mm flex in them. So if you pull on a belt, it should go as far as about 7-9mm. Don't overtighten the belts though as this puts stress on the pulley and bearings.
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    theres a product that i have seen, it was called 'belt grip' works a treat, as my mate used it on his ea falcon(common problem)
    VH SL/E 1982 commodore/WB ute x2 VP commodore
    Nov 2005
    Cairns Far Nth Qld
    tighten fan belt that works to u know
    Shawn Johnston
    Cairns Far Nth Qld
    Mobile:0488 530 009
    MSN: sbj_security@hotmail.com
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Don't use beltgrip while the engine's running, though - the sudden grip can actually cause the belt to grip and belt you in the face - not pretty I'd imagine
  1. how to tighten fanbelt on vs v6 ???
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2006, 01:43 PM
  2. fanbelt abjustment ???
    Last Post: 18-03-2006, 03:48 PM
  3. Help me with my vn troubles
    By vn_lexcen_s2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 07:41 PM
  4. Vt Troubles
    By da_doc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2005, 11:36 AM
  5. Fitting VN-V6 with air Fanbelt
    By ellbbq in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2005, 10:49 AM
