Results 1 to 8 of 8
Thread: VK - LPG - Wont start on fuel..
    EF Almost Turbo
    Jun 2005
    Default VK - LPG - Wont start on petrol..
    Hey all
    The VK Calais i recently got is duel fuel. How hre is my problem, it starts perfect on lpg, but i cant get it started on petrol. It just keeps trying until it sounds like it backfires?
    Any ideas?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
    Aug 2005
    Well, my duel fuel setup has been tuned for lpg, and have been told by the previous owner that it simply won't start on petrol, i admit, i have never tried, but i have it on good authority that it won't, so i don't risk it. So maybe yours is the same??
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    Prob i had, buggered solonoid. There should be two, one LPG, one Petrol. without tryin to start it, check that the solonoid trips when you change from LPG to petrol or vice versa
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    EFI 202 or carb V8?
    For EFI, it's probably clogged injectors. Get them cleaned. For carburettor, keep cranking it and see if you can see fuel in the carb squirting out the jets.
    EF Almost Turbo
    Jun 2005
    ok, its efi.. the switch between lpg/petrol DOES click.
    I was suggested the injectors may be clogged and its cheaper to replace then clean.. is this true?
    EDIT: Mostly itll backfire or nothing will happen.. on one try however.. it almost started.. sounded like it was going to, but it just backfired instead..
    DaZ
    The_Monk says:
    im a leech
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Yeah that sounds like it has part of the head firing but not the rest. Mind you, I accidently got a pair of my spark leads around the wrong way and it ran rough and then backfired and cut out.
    It does sound like clogged injectors to me but I ain't a very knowledgable person on EFI cars. I would leave it to someone else to answer. Maybe Scott (vkberlina) might be lurking around
    EF Almost Turbo
    Jun 2005
    Well its in the LPG centre. So far, the AFM is officially dead.. replacing it tomorrow.. tuning it up.. should help.. been told its more than the AFM stopping it from starting..
    DaZ
    The_Monk says:
    im a leech
  1. wont start
    By byt in forum Electrical Wiring / Questions
    Last Post: 03-12-2009, 08:33 PM
  2. VL Wont Start
    By boycee in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-04-2007, 10:20 PM
  3. Vr Wont Start!!!
    By tommo824 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2006, 03:29 PM
  4. 3.3 efi duel fuel wont start
    By vkefi in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 12:58 AM
  5. Help wont start
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2005, 05:16 AM
