Digi-dash at 411,000 kms now and still working fine!!!
Running on a 3.3L carb engine, getting ready to reinstall the fuel injection soon.
Only problem I've had was that the transmission went a few months back and when I installed the replacement, the gear inside the tran's for the speedo cable sheared so no speedo.
It now has two magnets attached to the tailshaft with a hall effect (magnetic field) sensor mounted nearby, and a few bits of electronics bought from Jaycar... no more speedo transducer or mechanical cables on this one... purely electronic as it should have been from factory in my opinion.
most common issue i see with them is the low coolant sensor which is not even the gauges its usually the sender
SIR LS1
the two ton go kart
mmmthread dig!
So this summer I'm going to muck around with the digital dash I have from a calais I wrecked and get it all up and running in my carby 202 vk. Hope I didnt throw out all the parts I need! Anyone have a schematic of the guts of the dash itself? I may feel like getting creative and performing a few mods on it.
