I need some advice as to where the best place is to hook up 12 volts through the ignition to a pro comp all in one dizzy. Most 12 volt power I have found cuts out on ignition. The dizzy works fine direct from the battery but obviously I need the power to cut off when I turn off the ignition. The car is a VK 5 litre (308) Calais. Cheers Rossco
Wouldn't you use the same wire that connects to your coil which is controlled by the key? When you turn your key off, the coil stops energising right? So the wire is on the +ve side of the coil.
Have you got any pics of your Calais?![]()
I have tried the coil wire but it it has power right through to ignition and then it shuts off. That is why I am looking for another source. I have tried some others in the black box but the same thing happens. Cheers
