Hey guys
Just after a bit of help with my new engine and which way to go.
i have a black 202 with a T5 borg worner which i was thinking about boring 30 tho using flattops pistons
A crowcam 40/90 or bigger
standard oil pump
acl bearings
ignition from a auto motor
yella terra head stage 5
rolla rockers
webber 34adm duel throat
regrind on crank
just wondering what u think and any changes or suggestions that u guys have. Also if u guys no what sorta power i would be looking at.
cheers
Graeme
it all sounds impressive but if you want to drive it on the road i suggest you back it off a little
That sounds like a speedmachine!
Go hard mate![]()
If you've got the money how about injecting it?
It realy improves the drivability when tuned correctly.
VK EFI parts are becoming cheep now, plus you can mod a VN comp cheep or go an after market.
I'm pushing 107.9 rwkw out of mine with After Market EFI comp standard VK Manifolds.
Only other mods are
Roller rockers, valve springs, mild CAM and 2.5" exhaust
You should expect plenty more then
