View Poll Results: This thread a good idea?
Voters
199. You may not vote on this poll
  • Yes
    197 98.99%
  • No (please explain why)
    2 1.01%
Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
Like Tree1Likes
Thread: Everything to know about VB - VKs
  1. #26
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    does anyone have anything for the vt disk brake conversion?
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
  2. #27
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
  3. #28
    VS ute
    Jan 2010
    townsville
  4. #29
    dan202's Avatar
    dan202 is offline ITZ A PIG
    I HOT VR
    Jul 2009
    lancefield
    Question vh sle
    hi there i have a vh sle in my profile and a vc turned into a vk brock mock up and the heaters both work well and the blow hot air to the feet and windscreen but always blow cold air to face and sidevents any ideas?
  5. #30
    vk commodore
    Feb 2010
    i just wana know what the differnce is with vk calipers 2 vn. i am getting rid of the drums.
  6. #31
    Vh Povo 202
    Aug 2010
    sydney
    commodore vb 3.3L '79
    Oct 2010
    n.s.w.
    Default commodore vb
    hi
    I want to know about how much my commodre vb 3.3L gold sedan '79 92,379km would be approximately evaluated??
    If you know ,please!!
  8. #33
    VL V8
    Nov 2010
    perth wa
    Hey any one no the crank tighting proceeder on a black 308 as it was lowered to do the rear main
  9. #34
    VL V8
    Nov 2010
    perth wa
    Hey there wondering if no tighting prceeder on crank after doing rear main seal on 308 black motor cherrs molnar1
  10. #35
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    Quote Originally Posted by shingo View Post
    hi
    what is its condition? according to unique cars value guide if it has excellent paint, fresh interior, and mechanically fantastic, about $5000. If it is a reasonable daily driver (some minor paint defects, mechanical issues), $3000. If it is a beater than $1000-1500.
  11. #36
    VH/SL
    Nov 2010
    australia
    vn calais vc vn
    Nov 2010
    vic
    this is very interesting great write up i am wondering if you are able to do the same ( if you have the knoweledge on it ) for a conversion to turn a vc commadore into a v6 vn powered one ( want a lil bit more tech under the hood ) if some one here can help me that would be great
    thanks in advance guys
  13. #38
    holden Commodore vh
    Jan 2011
    Noble Park
    does anyone know anywhere or anyone selling a 202 motor that i can put in my vh commdore.?
  14. #39
    vk
    Mar 2011
    Upper Hutt, wellington,New Zealand
    Hi guys and gals, how do i remove the radius arm bushes from my vk commadore, changing from rubber to nolathane for racing..cheers
  15. #40
    vk
    Mar 2011
    VK Executive
    Jul 2008
    I fitted a VL V8 diff to my 6cyl VK SL, the diff came with VL disks and calipers brake lines and handbrake cable. Removed the old drums with the old diff bolted up all the VL rear end and then bolted up my 15/16 4WD master. all has seemed good up until I needed to brake a bit harder than normal and the started fishtailing. I seem to have too much brake bias to the rear. This could be due to rear tyres being a litle low on tread or my shockers being less than bran new but I am pretty sure the standard 6cyl VK front disks are below par. I would recommend at least changing to the VL 298mm rotors with matching calipers and 15inch wheels (I still have the 14s) But I am looking at doing a 330mm rotor and twin piston caliper upgrade on mine along with a 17inch wheel upgrade to fit over the brakes. Then maybe fitting adjustable height struts with new shockers. All in the interest of pulling up straight again. It used to pull up dead straight with the original disk/drum standard combo.
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
  17. #42
    ari666's Avatar
    1966 impala
    Mar 2009
  18. #43
    VK Executive
    Jul 2008
    Does the VK with rear drums and a 15/16 have a proportioning valve? I cant see one in the lines anywhere. If a VL has one then maybe I need to fit one. Brakes were well bled after the conversion was finished and pedal feels firm and doesnt fade when held on for an extended period of time so dont think I have air in lines.
    To add to the post:- Found the proportioning valve its built into the master cylinder. There is a chance it could have been dicky as it came from a wrecked VK calais 6cyl EFI.
    The front rotors are smaller than the rear ones.
    The Front rotors have been changed to 330mm, Calipers are now PBR C4 twin piston and master cyl is 1 inch new PBR. Brakes pull up real well now. From high speed can jam on the brakes as hard as I like and will slow down completely even and eyeball poppingly quick.
    Everything to know about VB - VKs-std_disk.jpgEverything to know about VB - VKs-330mm_c4.jpg
    VK Turbo build
    My Forum
    Email me
  19. #44
    vy calais
    Oct 2011
    Tea Gardens
    Hello!!
    Im not sure if this is the right place to be asking, but i have 2 vk's sitting at my fathers property.I want to get rid of them but i have no idea what type of engine etc they have in them or what they would be worth. I have taken photos of them both got the eng number etc so here goes:
    1. model: VK8VK19-134. SEPT 85. ENG V7X ---manual too (car smashed up thanks to young kids, gosh the kids today) hasnt been started in over 18 months either
    2. model: VK8VL19-233. MAR 84 . ENG L31--- auto berlina with 77000kms still has original everything unver bonnet & even back visors!!
    If any one could help me out that would super!! And nothing too technical.... im a female!!
  20. #45
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    ENG V7X, 304 ci V8. Eng L31, 308.
  21. #46
    Vk commodore ex pursuit
    Jan 2012
    Darwin
    anyone know anything about fitting a turbo 700 from a 304 vq statesman into a 308 vk?? the vk currently has a toploader so i have two different crossmembers. anyone know what has to be done for fitment?
  22. #47
    1979sle commodore
    Feb 2012
    auckland.nz
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Rare spares might have the guard ones still.
  24. #49
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    anybody know where to get a red 3.3 liter decal??? ebay or rare spares has none..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
