Results 1 to 12 of 12
Thread: rb 30 into vk
    vk_wagon's Avatar
    vk_wagon is offline my vk on equus 20's
    vk 84 on 20's
    Jul 2005
    Default rb 30 into vk
    hi peoples have a few qeustions i have a vk i was originaly gonna go 5ltr 308 out of another vk but cant find any than thought go efi then stopped and thought about a super charged v6 now thinkin about a rb30 in it cause v6 is a bit of work and alot of money ie engineers certificate plus more would it fit straight in? do you reckon its worth putin a rb30 or go turbo (rb30et) ?
    VH SLE
    Nov 2005
    definately go a turbo if your gonna do the work then it way as well be really quick.
    "From where i was, it looked like the cars you were overtaking were sitting still"
    Check out my VH SL/E
    http://forums.justcommodores.com.au/...ad.php?t=23160
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Sounds like a big project mate, sounds like a good idea to ! why not give the oldies a new boost in todays tech!
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Yeah its been done and is pretty much a bolt in job. search calais turbo forum there is one there. You will need an engineers certificate if you put an rb30e or an rb30et (with the rb30et you will need a vl turbo driveline and ecu and you will need turbo or v8 brakes.)
    ========My Statesman 20's Mafless and 3.9's========
    vk_wagon's Avatar
    vk 84 on 20's
    Jul 2005
    Default sweet
    im intending to go disks all round anyway just trying to make my mind up whether to go rb30,e,et or just go v6 or 8 mmm my choice is hard im unsure but its all gotta do with money really i have all the time in the world to do just not enough doe. ive heard ppl are waisting the time on working the black 202 carbie or efi but i dont see the point ive had 2 vks and both had 202 blacks in it one just kept blowing head gasjets and the other always had a problem with the est but hell i would blame it after the trashing they took at the burn out night at eastern creek on wenesday nights lol thanks for the info more is welcome
    RACE5L's Avatar
    RACE5L is offline Solid cammed
    VH 355
    Sep 2004
    I was at a Street Machine Commodores photoshoot today and one of the cars was an RB30 Turbo VH, Only major mod was a gearbox crossmember, fit a VL crossmember and the rest is almost bolt in if you know an auto elec. Only difference is room for cat convertor.
    VK 3.3
    Apr 2006
    QLD, Regents Park
    vn ss
    Oct 2005
    if u really wanna go the turbo then do it. if it was me i would put an injected 5 litre under the bonnet. but each to their own.
    EF Almost Turbo
    Jun 2005
    your going ot need an engineers for anything but a 308.. so why not go 5L EFI?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    you will need an engineers certifcate if a non standard motor with larger capacity or increased power is fitted to the car,
    In some states its called a blue plate.
    Turbos are not ricers LOL well not all of 'em anyway.
    RACE5L's Avatar
    VH 355
    Sep 2004
    Quote Originally Posted by VkCalaisDaZ
    In most states, every engine is classified as being different, even if the same engine but from a different period eg putting a vl 304 into a VB.
    Every engine falls under the emissions regs and Adr's of the original vehicle it was fitted to. So to put a HQ 308 into an early commodore, you would be given a no straight up, unless you can provide a certificate from an engine builder that it was the only block that he had to rebuild your engine to original spec, otherwise your other avenue is to get an engineer to approve you have fitted the applicable emissions devices(vc-vk: blue heads/manifold with egr etc/emissions carby and hoses).
    To fit a later model engine, you have to comply now with the engines emission specs. Fit a vl 304 and you might get asked to fit an unleaded tank with filler(easiest is VL tank) and a cat convertor and maybe consult an engineer. To add to this, if you go EFI, you need to use an engineer to approve conversion as all the vn-vt regulations will have to be met depending on model engine was originally fitted to.
    There are grey areas here depending on who blue slips your conversion, eg: some will let you get away with fitting an efi topend conversion onto an earlier vb-vk block(your original engine) without changing any other items or needing to comply it.
    Hope this helps
    RACE5L's Avatar
    VH 355
    Sep 2004
    Quote Originally Posted by Rosco666
    screw that rice *hit
    Cant see how a Holden fitted engine in another model can constitute as rice,
    some VB-VCs were fitted with turbos, Vk's had EFI on 6's. Im fitting an EFI topend to the 383 and supercharging at a later date. The good thing about Nige's purple VH(see Street Commo's Summernats issue #111) is that it stands out without being a total hybrid. His and two other nice VK's will be in the next Street Machine Commodores mag coming up mid year.
