Results 1 to 5 of 5
Thread: need traumatic for VH 2.85, will any do?
    VR Calais
    Apr 2005
    Default need traumatic for VH 2.85, will any do?
    I need a new gearbox for my VH, but I'm not sure if there were different models of trimatic made, or if any will do the job?
    I vaguely remember hearing soemthing about 202 trimatics being different or soemthing... duon't know...
    It's going to end it's life as a paddock-basher, so I'm not overly fussy, I just don't want to get something that might not bolt up
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Thumbs up
    Information taken from the GM VH manual...
    Transmission codes
    The transmission identification plate carries the transmission serial number and application code. The following codes are used for VH Series Trimatic Transmissions.
    Transmission code Engine
    FY 1.9 L4
    LL 2.8 L6
    FP 3.3 L6
    FR 4.2 V8
    Basically, if you get a transmission, it should have a tag on the side which says the transmission code.
    Technically I don't see why any six transmission wouldn't fit on your VH.
    VHSLX Guest
    VR Calais
    Apr 2005
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    They are all interchangable just make sure the bolt pattern is for your motor and the gear selector is on the correct side. (some are on the right and some are on the left)
    ========My Statesman 20's Mafless and 3.9's========
  1. gushing tranny fluid...traumatic indeed
    By Vk-5ltr Berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-01-2007, 09:55 AM
  2. Traumatic noise in reverse...
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2006, 02:52 AM
