Results 1 to 4 of 4
Thread: a couple of dumb questions for a VH ...
    VHSLX Guest
    Red face a couple of dumb questions for a VH ...
    Gday Guys ,
    Firstly , My Vaccum gauge is not working as its meant to , and when i was scouting around the Engine Bay earlier i found a small thin rubber hose with an end broken on it , i traced it to the back of the Carby , could this be the Cause ???
    Secondly , Is a Heater Core easy to pull out , if so can it be done by a complete tit ?
    Third , How do i fit a Tacho to the Car , im not talking about a big 'uleh' tacho for dragging , but the vaccumm gauge is where the tacho gauge should be in most other cars and im more interested in RPM not Hp1 , is there a way to fit one ? I seen Shawns VH Beast and he had three little ones in the compartment under the CD Player , I Like the Idea but his were for Voltage , So is there a Small Tacho or is it worth Replaciing the whole dash ??????
    And Last , I want to Cut the Rear Left Quarter off my Spare Parts Car and get it put on to my Good Car , Should i Attempt this on my own , or get a professional to do it , or is there anyone who could give me some hints on how to do it , im not scared to try but knowing what to cut first would be good !
    Any Help would be Appreciated
    Dont Forget i have everything from the parts car available , give me a bell ,
    Red
    VH SL/X Commodore , 2.5" Exhaust with Genie Extractors , GH Dynotuned
    For Sale - VH Commodore , Blue Motor on Gas with Tank (1.3 Years Left before Restamping ) , straight panels , Very Nice Good Blue Suede Interior , No RWC or REG , Good for Parts , $250
    VH V8
    Sep 2005
    hey,
    its easy to fit a tacho to the VH. the wires coming out of the tach go to igintion power, instrument cluster lights and then one to the negative side of the ignition coil.
    i ont know about changing the dash, but i guess you could. this way the wiring loom that plugs into it should already have the wires necessary for the tacho. the SS came out with the tacho in the dash, i dont know which others did, probably any of the manuals.
    with the vac gauge, it could be that pipe, does it "suck"onto your finger while the car is running? there may be another pipe that is causing hte faulty readings.
    i am unsure about the heater core, what the problem with it?
    hope some of this helps
    VE SII Sv6 Manual
    Aug 2004
    You can Pick up an SLE dash from VB to VH they'll have the tacho plus volt and oil pressure gauges. Then you change the oil pressure switch to pressure sensor. Picked one up for about $30 - $50 think it was. then got tacho recalibrated to 6 Cylinder.
    VY Executive 3.8
    Mar 2006
    you can pick up heaps of stuff on ebay, even idividual dials rather than whole dashes..
  1. couple of vl questions.
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-01-2007, 06:40 PM
  2. Couple of questions - regarding my VC
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-01-2007, 05:35 PM
  3. A couple of questions.
    By 97 SEN in forum Car Audio
    Last Post: 14-07-2006, 01:18 PM
  4. Couple of questions
    By jwood in forum General
    Last Post: 10-07-2006, 11:15 PM
  5. Snappy Answers to Dumb Tourist Questions....
    By rattattack1313 in forum Jokes/Humour
    Last Post: 06-11-2005, 10:10 PM
