Results 1 to 7 of 7
Thread: Vh Ss
    VH V8
    Sep 2005
    Default Vh Ss
    hey guys
    im just looking at a VH SS, and was wondering if they had hte HDT plate anywhere under the bonnet? or even if it is an original SS.
    the numbers are
    VH8VK69-XV2
    593702-A
    1980-79T
    IF075-D
    built in MAY 83
    L31 M21 CU4
    the interior feels like wool! it has dominant black stitching.... and is a light brown, crossed with dark brown.
    any info on this car would be appreciated. it has rear discs, lsd, and also an immobiliser, but i dont know if that is stock or not.
    cheers
    vincent
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Only the Group 1, 2 or 3 has the HDT plate under the bonnet.
    Those numbers that you have posted up are proper VH SS numbers.
    They all had LSD diffs, this one has the bigger 10 bolt Sals.
    The interior is a mixture of tweed cloth and vinyl in a darker claret colour.
    The L31 is a 308 blue 5litre(a lucky SS) M21 aussie close ratio 4 speed manual
    the CU4 is not the correct code, should be GU4 which is 3.08:1 diff ratio
    593702-A is the body number, A is an Adelaide built commodore
    1980-79T trim code. 1980 is the colour(dark claret) 79T tweed cloth
    IF075-D Paint code. I think the colour is red(not good with paint codes).
    I have a single sheet VH SS sales brochure here, doesn't have much info though.
    I hope this helps
    VH V8
    Sep 2005
    hey
    thanks for that
    yeah its red, with a dark marone/purple interior.
    what are these cars worth?
    thanks
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well anything between $1500-9000 really. These cars are the base for HDT VH SS Group 1, 2 or 3.
    VH V8
    Sep 2005
    the one i am looking at has a perfectly straight body, but is in paint primer, and needs a respray. engine seems pretty good, leaking from what apears to be rear main seal. has AC, powersteering.
    do you konw what kW these engines put out?
    how much would i be looking at for a decent spray job, in original red ofcourse.
    are these SS pretty rare?
    thanks
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    yes they are rare. But sounds like someone put the AC on it cause they wasn't factory.
    I think the pump out 126kW.
    Oh the red is Marenello Red(spelling). Usually red paints is one of the dearest cause everyone wants it!.
    You should pay $5000 or more for a top notch respray
    2x VS
    Jul 2005
    Quote Originally Posted by bigg_vin
    thanks
    Yeah I'd say they are becoming that way now due to age...cheap price and the teenagers writing them off.
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
