Results 1 to 6 of 6
Thread: 3.8 into a vk. Do i need an engineering certificate
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    Default 3.8 into a vk. Do i need an engineering certificate
    Hey all, just a question, iv seen 3.8 v6's from vn's go into vk's, i can get my hands on a cheap engine but i am not sure if i install it properly (not bodgy) do i still need a engineers certificate or do i just get it inspected for rego?
    cheers any comments would be appreciated
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :(
    VN Vacationer
    May 2005
    Sydney, NSW
    Pretty sure you'd need an engineers, as the engine was not an option for that car. May be wrong though
    Aug 2005
    I would imagine that it would have to have an engineer cert. As you will be changing the engine mounts, fuel lines (?) etc. I have read that an engineer cert should be around the 500 mark, again, just trying to remember stuff that i've previously read, so forgive me if i am wrong.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Yes you will need an engineers certificate if you go to a larger engine or a newer non standard engine. This will require things like the installation being up to scratch and the wiring is all correct and safe and that the brakes are up to the task (you will need 4 wheel discs as minimum). You will need to modify the floor of the car for a place to put the CAT or CATS and all the pollution gear for that particular motor must be installed and working correctly.
    ========My Statesman 20's Mafless and 3.9's========
    DAMO_5L's Avatar
    DAMO_5L is offline ILLEGAL
    VN turbo 5L V8 aero, Rodeo minitruck, VR SS 355
    Jan 2006
    maryborough
    all u need is a blue plate. u can use all the same fuel lines and shit but a bigger fuel pump. i got a vk with a vp 3.8 and its wicked. make sure u have the dash or the gauges out the old car to put in and u have to have a disc back end.
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    thanx guys u have been a big help, ill keep you posted on my progress
    cheers
  1. HSV Certificate
    By dannad in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2007, 01:33 PM
  2. engineering in qld...
    By cruzncommo in forum General
    Last Post: 15-02-2007, 05:27 PM
  3. great engineering
    By 2002 VY in forum Jokes/Humour
    Last Post: 29-07-2006, 07:40 AM
  4. Engineering
    By Bax in forum General
    Last Post: 29-05-2006, 04:46 PM
  5. engineering certificate?????
    By UNEQVN in forum General Discussion
    Last Post: 10-07-2005, 10:51 PM
