Results 1 to 12 of 12
Thread: wierd problem
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Default wierd problem
    every now and then when i turn my VK off, and go to start it again say 5 minutes later, it wont even turn over, the accessories come on, but the engine wont make a sound.. then about 5 minutes after that i turn the key and it starts perfectly. it seems to only happen if ive had my parkers on before i turned the car off.
    cheers.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Could be the starter motor solinoid(spelling is off) up the creek.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Feb 2006
    Radelaide
    Quote Originally Posted by Goon
    Your battery could be screwed, it may not be charging right.
    nah the battery is fine
    Goon's Avatar
    Feb 2006
    GC. QLD
    Do what SL/ENut said then check your alternator, spark plugs..
    A fuse could even be lose..
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I was more thinking of a possible dodgy neutral start switch. If it happens again, put the stick through gears and back into park or into neutral and see if it starts right away.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Those things have nothing to do with his problem.
    Morgasshk is offline Morgasshk
    VY Exec 3.8L Sedan 9C1 Pack
    Aug 2005
    is it even ticking? like going to engage?
    beat crap outta your starter motor with a club lock or something.. :P mate has the same problem atm, with his VB/K... new starter motor too... peicea shite...
    Goon's Avatar
    Feb 2006
    GC. QLD
    lol Zoist that's my mind running on rum for ya
    The problem does sound like the starter motor, i know with a manual u could try putting her in gear and rocking her back and forth a few times then try starting her, but if u own a auto i'm not sure if this would have the same effect - Overall it would pin point that ur issue is the starter motor. "starter motor/wires"
    EF Almost Turbo
    Jun 2005
    i used to have this problem.. my barrel was out fo alignment and seemed to love going to a point between "start" and "on"..
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    VS Stato SII L67 S/C V6
    Apr 2004
    had this problem also
    was a combination of rooted barrel, and a stuffed EST system, one of the sensors died or something, the autoelec told me it was a waste of time diagnosing, and i never looked back
    you can get a NICE barrel from repco for about $40, and they are far superior to the genuine holden unit
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Yeah faulty starter motor or starter solenoid, My torana had this problem sometimes just give it a tap with a hammer and see if that does it.
    ========My Statesman 20's Mafless and 3.9's========
  1. VS S2 Senator Manual, Wierd Geabox problem
    By adzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2007, 09:24 AM
  2. Wierd SS grill??
    By 2_SeeK_U in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2006, 05:35 PM
  3. Very wierd electrical problem
    By down_with_the_system in forum Electrical Wiring / Questions
    Last Post: 19-04-2006, 09:53 PM
  4. tHIS IS SOME WIERD STUFF
    By coolngroovy in forum The Pub
    Last Post: 10-01-2006, 07:13 PM
  5. wierd noise in my vn
    By nafe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2006, 11:29 PM
