Results 1 to 15 of 15
Thread: manual box
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    Default manual box
    hey there, got myself an old VB red 202 and is backed by a shitty ol' trimatic, i have a donor VC BLUE 202 blown with a 5 speed, just wanting to know if the flywheel and all the input shaft off the VC would fit, and also the driveshaft, just want to know really if a blue fywheel will fit on a red motor?
    cheers, nick
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yes, yes it will, just make sure you use all the components from the blue one, inc. the flywheel bolts, inspection plate and the clutch parts... Just remember, a new spigot will never go astray while its all in bits, k...
    May 2005
    Mildura
    awesome, just wasnt sure if the blue flywheel had the same holes as red, and yeah i will use everything from the blue, but im buying new clutch and pressure plate as well as a new spigot, also what sort of 5 speed did they put in VC's? i havent looked at it yet, but i didnt know they had 5 speeds. cheers for your help.
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    I have a feeling the 5-speed is a small borg-warner box, not like the ones in the VN's onwards tho...
    VK 3.3
    Apr 2006
    QLD, Regents Park
    May 2005
    Mildura
    im not too fussed any manual is better than the auto behind it at the moment, i will have a look when i get it out
    84 VK 3.3 Converted to EFI
    Nov 2005
    whattabout the aussie4speeds r they any good for 3.3 my trimactic just died so i'm getting 1 very soon....cheers
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    just out of curiosity as we're on the topic, wot 5spds would fit a 1900cc VC, the 4spd i got is not far off gone.
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    the aussie 4-speed's are not too bad, prob stronger than the 5-speed...
    If you were to go an aussie 4-spd, try to get your hands on an m-21 (you'll pay extra tho), they have a good ratio and are stronger than the m-20, which was the standard one for the commodore...
    Personally, i'd fork out the bit extra and go the toyota box, clica - good for your money, but if you want major strength, go the supra box...
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Quote Originally Posted by dolphin14
    The M76 5speed is a straight bolt up job to the misfire4, Infact any box from behind the L6 engines will bolt up, as the Starfire engine is just a 2850 six with two cylinders lopped off!!!
    My first car was a 4cyl VC with MC6 box. I have some very fond memorys of that car, the driveline is not one of them.
    Nov 2005
    i ended up getting a philo4speed is there much diff to the aussie made 1's
    Sep 2005
    Newcastle
    Quote Originally Posted by figjamidhVK8t4
    Yes they are a totally different design, gear ratios are different as well. The "philo" was called the torquemaster 4 speed by Holden, this referred to its super low first gear not its torque handling ability. Mate I suggest that you put the one you've got in and see how you like it. If you do like it good luck to you, If you don't start saving for somthing better. If you plan to keep the car long term then save up for a supra or T5 conversion.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    the torquemasters are weak thats for just don't thrash it and it might last long enough to buy something better i hope you got the speedo cable with it.
    Sep 2005
    Newcastle
    Quote Originally Posted by atrail308
    A Supra 5speed would be major overkill behind a Misfire4 don't you think. The M76s were unbreakable behind the old boatanchor4.
  15. #15
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    Quote Originally Posted by tigervh
    i was reffering to the message about the aussie 4 speed behind a 3.3, not the next message about the starfire.... and yes, a supra box would be an overkill for the starfire...
  1. WTB: Manual conversion or wrecked vn-vr manual
    By na3point8 in forum Parts And Other Items For Sale
    Last Post: 13-03-2007, 10:22 PM
  2. FS: VH Workshop manual and Owners manual
    By pro_gmh in forum Parts And Other Items For Sale
    Last Post: 27-09-2006, 10:36 PM
  3. vn manual to ford manual??
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2006, 06:58 PM
  4. difference between v6 manual - v8 manual
    Last Post: 22-03-2006, 08:46 PM
  5. WTT: camira service manual for a VP sevice manual
    By sparra_gump in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2005, 01:18 PM
