Results 1 to 6 of 6
Thread: An EFI question. :p
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Question An EFI question.
    Hey All
    Just wondering if it was possible to get efi for a blue 202, i know you can for the red motors but i've never seen efi for a blue....
    VE SII Sv6 Manual
    Aug 2004
    efi fits the blue better than the red motor.
    blue/black motors have same head port layout, virtualy the same motor.
    red motor you need to change the head over to blue/black.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by Goon
    Hey All
    Some people refer to the VK EFI 202 engine as a "red" engine due to the red rocker cover & injection manifold.
    To actually fit the injection to a red motor requires more than just chaning the head as water jackets etc dont line exactly up.
    Other mods are required to a carbie car other than bolting up the injection manifold.
    including
    rerouting fuel lines, adding a fuel return line
    removing mechanical fuel pump
    installing high pressure pump
    wiring, computer, and sensors
    fitting of a air box & AFM
    if oyur using a standard VK eFI setup a hold will need to be drilled in the engine block to allow for a sensor which is located on the dizzy side of the block towards the rear.
    installation of tube headers replacing the cast iron headers as well.
    Also to gain the best perfomance etc a cam shaft change is recommended as well and an EFI car runs a different cam profile.
    cheers
    Scott
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Yes efi will fit on a blue motor because blue and black are almost identical mechanically. There was an old article in street machine, I think it was called grunt hunt and they just did everything they could to a blue motor EFI, YT head, roller rockers,cam,starfire rods etc..
    ========My Statesman 20's Mafless and 3.9's========
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks heaps for the info, but i think ill stick with fuel straight to the carby instead
    Maybe in the future i might go EFI
    VK V8 Calais
    Jun 2005
    Adelaide, SA
    Smart move.
  1. just a question
    By fpr_thunder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2007, 11:34 AM
  2. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  3. V8 or not V8 - that is the question
    By SSV8pilot in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-08-2006, 09:10 AM
  4. VZ ute question
    By Troy711 in forum Car Audio
    Last Post: 28-06-2005, 09:27 PM
