Results 1 to 8 of 8
Thread: VK problems - HELP!
    EF Almost Turbo
    Jun 2005
    Default VK problems - HELP!
    Hey all
    My VK Calais has a problem which im hoping someone here can help me with.
    It doesnt go over 16km/hour and wont rev over 1500 rpm.. before this it backfired n had a bad odur. It does start, so i dont think its a spark issue.
    its a 202 on dedicated LPG..
    any ideas?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    If it picks up air after the AFM does it have an air filter there? I don't even know how a gas system really works, does it have a gas pump? I dunno LOL is the pressure of the gas tank enough to send the gas to the mixer alone?
    ========My Statesman 20's Mafless and 3.9's========
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Does she run fine on fuel? Could be the fuel.lpg lines.. Maybe even carby.
    I hope you havent been pushing her to hard
    EF Almost Turbo
    Jun 2005
    shes EFI, so no carby, and dedicated LPG, ive been tinkering with the lpg mixture and its making improvements..
    now i think shes not getting enough LPG.. airflow is fine.. but shes got no go
    itd take literlly 5 min to reach 70km/h
    DaZ
    The_Monk says:
    im a leech
    VK V8 Calais
    Jun 2005
    Adelaide, SA
    Default Backfire perhaps?
    Has your engine suffered a major backfire out through your airflow meter? If it has, I dare say you've damaged it and it's not opening fully allowing air into your engine to burn with your LPG.
    Silver
    corcaigh@internode.on.net
    EF Almost Turbo
    Jun 2005
    ys it did backfire, however the lpg takes the air before the airflow meter.. its current airflow meter is f****d and i didnt change it as it uses lpg only.
    DaZ
    The_Monk says:
    im a leech
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    give it a go on petrol with a replaced a/f meter and see how you go... this method will round down your prob letting you know if its the gas system or a/f meter, it should be only one of those two to cause the prob...
    EF Almost Turbo
    Jun 2005
    turns out it was the airflow meter. All good now
    DaZ
    The_Monk says:
    im a leech
  1. VL problems plz help
    By garysvl in forum General
    Last Post: 02-09-2008, 06:10 AM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  3. vn sII into vg what problems
    By rob85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 08:50 AM
  4. LPG Problems
    By Shounak in forum General
    Last Post: 30-01-2006, 03:19 PM
  5. The VR of VR problems
    By Cowz in forum Electrical Wiring / Questions
    Last Post: 09-05-2005, 12:04 PM
