Results 1 to 8 of 8
Thread: Black 3.3 pinging
    VK 3.3
    Feb 2006
    Default Black 3.3 pinging
    Does anyone know why the black motors are so prone to pinging. Is it the EST computer, the carby running rich and carboning up the cylinder head, the shape of the combustion chamber? I wouldn't think it was because of too high a compression.
    I have disconnected the EST, put in elect dizzy, put a kit thru the carby and decarboned the head. I've even smoothed out the combustion chamber, getting rid of the ridge. It has helped but still pings occasionally.
    A mechanic told me that he rang GMH once and they told him to use TWO head gaskets.
    I have another engine that I am putting together, so any help would be appreciated before I get too far.
    Cheers, Big Al
    Spike79's Avatar
    Spike79 is offline Just Confused!
    VZ Adventra LX6, VP Berlina LX, Citroen C3
    Bubble Shooter Champion! X-Pipes Champion! Alu`s Revenge Champion!
    Feb 2006
    Brisbane N/W Ferny Hills
    This might be a bit too obvious but what petrol are you using?
    Have you got a high enough octane rating? I think it should be 97octane, unfortunately this means using PULP or putting an octane booster in the tank.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by Spike79
    Or just buying 98 octane fuel at the bowser either Optimax, Ultimate 98, Vortex or Synergy 8000 (I think its 8000)
    sed8's Avatar
    sed8 is offline commodore nut
    vr ute @ vk calais
    Feb 2005
    brisbane
    VK 3.3i, V6 VL in Production
    Apr 2006
    Bathurst NSW
    I have an EFI 202 that pings its nut out on ULP. I run PULP and use Nulon Octane Boost. An airforce mechanic put me onto it and it doesn't cost heaps. It gives you an octane boost, injector/carb cleaner and upper cylinder lube (which the older leaded motors need). Thats an easy and cheap fix, try it and see how you go.
    Kain
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    yea i did the same thing as darkmoon on my vk worked a treat i stand by nulon products
    1994 VR Exec, 5.0L BT1
    Jan 2005
    Quote Originally Posted by darkmoon
    Kain
    Sounds like a good thing. Do you still need to use a valve saver? How much does it cost?
    VK 3.3
    Feb 2006
    Thanx guys, Octane booster did the trick. But what I really wanted to know is why the black motors are more inclined to ping than say the red motors. Black motor comp. ratio 8.8-1, red motor 9.2-1 so you would think that the red motors would ping more?? Is it because the red heads have a different shape, or is it the computer in the VKs or something else?
    Cheers, Big Al
  1. pinging
    By tougHnA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2006, 10:47 PM
  2. Pinging
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2006, 12:52 AM
  3. pinging
    By skb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2006, 11:33 PM
  4. pinging
    By chris_1987_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-11-2005, 12:29 PM
  5. VR 5L pinging!
    By calais5l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2004, 08:49 PM
