Results 1 to 23 of 23
Thread: How the Hell?
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    Angry How the Hell?
    may be a stupid question, but how the hell does the steering wheel come off a VC commy?
    i know of the splined shaft, and as far as i know there is just the centre nut on the actual steering shaft (under horn switch) to undo.
    ive tried EVERYTHING, short of an angle grinder to get it off, but it hasn't budged. So what else am i missing?
    BTW, ive spent all day at it, so i needed a vent.
    308commodore's Avatar
    308commodore is offline 308 commodore
    308 VK CALAIS
    Mar 2005
    camira, queensland
    Thumbs up
    Same happened to me when i went pull my wheel off my calais but it can be done. The way i was shown was to undo the nut on the colum so it sits flush with the shaft. with one foot on the brake pedal and one hand on the top of the steering wheel, pull the wheel towards you with a little bit of force. Now with your spare hand grab a hammer and bash the nut on the steering shaft. If you pull the wheel and bash the nut at the same time your wheel should pry loose. then it's just a matter of unbolting the nut and taking off the wheel.
    I HOPE THIS HELPS.
    GOOD LUCK...
    GO THE ALLMIGHTY HOLDEN 308
    Sep 2005
    Opononi, NZ
    good idea, but i tried that, actually had my dad pulling the top, me pulling the bottom and my sista hitting the nut, didn't move.
    thx anyway
    Sep 2005
    Opononi, NZ
    even had a hydraulic jack on the nut with old seat belt strap around the wheel and it STILL didn't move.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    You cant remove the nut?
    You could try socket set, WD 40 , I hope it hasnt been welded on .. Even while using the socket set, try the good old trust pipe for a helping push .
    bommodore Guest
    time to go and buy the right tool for the job its called a steering wheel puller or if you have a flywheel puller for a mower it might do and a lot of cursing and swearing will always help
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    yep, steering wheel puller for the win. not that expensive and easy to use. and wont' damage stuff.
    ECOTEC KICKED IN yO!!!!!!
    Spike79's Avatar
    Spike79 is offline Just Confused!
    VZ Adventra LX6, VP Berlina LX, Citroen C3
    Bubble Shooter Champion! X-Pipes Champion! Alu`s Revenge Champion!
    Feb 2006
    Brisbane N/W Ferny Hills
    Oh Dolphin14, i feel your pain mate, its a prick of a job.
    I have to agree with the other guys, get yourself a wheel-puller.
    Just a tip though (even though its a bit late) Don't hit the steering column, it can seriously bugger up the energy absorbing part of the column.
    Good luck!
    Sep 2005
    Opononi, NZ
    got wheel pullers, and sorry guys, they didn't work either. Thx for the tip, no hitting.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok a way I have gotten nearly every tight steering wheel off a car is to loosed the nut off and tighten the lock nut up to the nut.
    Next go for a drive most of the time the steering wheel is loose in the first 5 corners.
    cheers
    Scott
    May 2004
    darwin
    Goon's Avatar
    Feb 2006
    GC. QLD
    vkberlina Ok a way I have gotten nearly every tight steering wheel off a car is to loosed the nut off and tighten the lock nut up to the nut.
    This trick could work and ive seen it been done alongtime ago
    Sep 2005
    Opononi, NZ
    Sep 2005
    Opononi, NZ
    SUCCESS, combination of everything did it, swearing and cursing, wheel pullers with "slight tapping" behind with me wiggling and pulling.
    The bastard is finally off.
    thanks all for advice
  15. #15
    Goon's Avatar
    Feb 2006
    GC. QLD
  16. #16
    bommodore Guest
  17. #17
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Quote Originally Posted by dolphin14
    If you have to ask questions like this, I suggest you buy yourself a workshop manual. It will answer this question and most others you may have in the future. You wont have to wade through a hole heap of dodgy internet posts from people who dont know shit.
  18. #18
    Spike79's Avatar
    Feb 2006
    Quote Originally Posted by tigervh
    Yeah, posts like yours! Thats a bit harsh don't you think?
    I couldn't agree more on your idea of getting a workshop manual, it is a very valuable resource.
    However i think you'll find that most but not all of the suggestion given could have come straight from a workshop manual or from the mouth of a qualified mechanic.
    Also remember the general idea of these forums is a place for people to seek advice on problems they have. At a guess i'd say 75% of the threads in this forum are seeking advice, and there are plenty of people willing to give them some help.
    Generally, its not a good idea to insult your fellow JC members. I don't know, perhaps you've had a bad day and just want to take it out on someone.
    In short though, if you don't like what you see here... You know where to go!
  19. #19
    Goon's Avatar
    Feb 2006
    GC. QLD
    Tigervh i don't know what your is mate, i have a workshop manual myself but you really should take it elsewhere.
  20. #20
    Sep 2005
    Opononi, NZ
    i appreciate ur oppinion, u try find a VC manual in Northland NZ. I asked for help, not ppl to flame others when lending advice.
  21. #21
    Goon's Avatar
    Feb 2006
    GC. QLD
    If your after a manual dolphin may i suggest ebay, thats where i got mine from
    But then again the manual doesnt alwasy tell you how to do everything.. thats 4 sure!
  22. #22
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    go to repco or supercrap
    they sell them
  23. #23
    Sep 2005
    Opononi, NZ
    cheers, ive picked one up, it does say, and i quote " undo centre nut, and pull on steering wheel". WTF happens if that doesn't work, that was the point of posting, just for Tigers sake, i tried the manual, and when that fails, then wot, IT DOESNT SAY.
    anyway, case closed, its done and finished.
  1. What the hell do I do???
    By TheForgotten in forum The Pub
    Last Post: 06-08-2006, 08:36 PM
  2. Omg What The Hell!
    By Z()LTAN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2006, 07:27 PM
  3. What the hell is that for!
    By BANGERS88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 07:00 PM
  4. Who The Hell
    By throttlehappy in forum The Pub
    Last Post: 07-12-2005, 09:31 PM
  5. What The Hell Is That!
    By bizzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2004, 03:44 PM
