Results 1 to 4 of 4
Thread: long-range fuel tank
    VYSS Crewman/ VX Berlina/ FG XR6T work car
    Jul 2005
    Default long-range fuel tank
    Can a vn-vp 80 litre tank be fitted to a VK sedan? Cheaper option than HDT.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    is the vk efi? if yes i would say maybe as i'm pretty sure the straps bolt up ok.
    EF Almost Turbo
    Jun 2005
    it will have to be efi to connect up properly
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Yes it can I run a tank out of a VQ statesman in my good VK you need to lengthen the passengers side strap to make it fit, & the fuel filler neck.
    As for fuel pumps the early tanks have a low pressure pump pumping fuel to the high pressure pump so it would need to be wired in. It should be low pressure enought for a carbie V8 and owuld just connect in like an existing fuel pump.
    Secondly if its going into a carbie 202 dont wire it up, if the engine pump cant draw the fuel through you may need to remove the internal pump from the pickup.
    cheers
    Scott
LinkBacks (?)
  1. 19-01-2012, 03:34 PM
  1. Long Range Fuel Tank...
    By Frandy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2006, 07:55 PM
  2. WTD: Long Range fuel tank 90l for VC
    By ssberlina in forum Swap / Wanted to Buy / Trade
    Last Post: 19-03-2006, 12:29 AM
  3. VS Ute Long Range Fuel Tank
    By camo's ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2005, 11:52 AM
  4. Wtb: Vlt Long Range Fuel Tank
    By YKORAY in forum Swap / Wanted to Buy / Trade
    Last Post: 11-09-2005, 04:23 PM
  5. VS UTE Long Range Fuel Tank
    By cleggy88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2005, 12:03 AM
