Results 1 to 13 of 13
Thread: 308 or 350
    vk executive. vr executive
    Feb 2006
    nz
    Default 308 or 350
    wanting to have feed back if i should put a 308 holden or a 350 chev in my 86 vk? as iv got a black top 202 est in it at the moment
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    small block chev
    I have said a heap of times, cheaper to hot up a 308, even throw in a EFi 5litre sounds better IMO
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Have you got a few thousand bucks? You would be better off buying a VK 308 with all the things you need instead of tracking down everything and changing your 202.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    If you do have the cash and you want muscle, i'd personal go with the 350 chev, I've heard of a 350 chev dusting today's skylines while still being stock..
    but then again buying a VK 308 as zoist said might not be a bad idea also
    Feb 2006
    nz
    Quote Originally Posted by zoist
    yer i could do that but iv got it sitting in the garage not doing much and have alot of time to make it work either way. and as i dont want to do it the easyt way and i want it to be custom
    Feb 2006
    nz
    Quote Originally Posted by Goon
    well skylines over here aint that shit hot the 202 gives them a good run
    ivabrocky Guest
    don't be a pussy, invest in a chevy 454 big block. jokes aside, used to own an hq wagon with a 308 with a lumpy cam, edelbrock headers, 650 holley carb and on the rare occasions when it was running nicely, before i parked it into the side of a building (excess speed while cornering + bad camber + big gutters + just wee bit of tequila = stumbling/running away from coppers, luckily laughing) was more than enough to always be grining when i drove it. just spend a few dollars on tweeking the 308 and you'll be happy.
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yeah, it'll be alot easier and cheaper building the holden motor...
    NEVER LATE WITH A 308...
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Why not fit a 355 stroker kit to the 308, their every bit as good as the chev if not better, cost a shit load less and don't require any engineering. Your insurance company and the cops will be none the wiser either.
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    What do u start with, more cubes or less. Cheaper to build a 308 but there is heaps of potential in a 350 plus u can get a lot of interisting goodies for them now.
    Grantis1976 Guest
    Lightbulb
    As tough as any V8 in a VK can be, a chev motor would be different, as there ain't many around......unfortunatly, thats for good reason.
    SBC into VB-L engine bay requires firewall massage, and brakebooster relocation, not by much, but alittle can be more of a pain in the ass than alot.
    If I had the money/time, I'd love to do a prostock theme VK with a 327.
    Concidering I dont own a wreakers, or oil company, I'd personaly go the injected 5L, and if need be, throw in a stroker kit for good measure.
    Having helped out b4 with this conversion, a couple of tips......keep in mind that EFI needs a fuel return from the engine bay, so keep that 6 cyl fuel system, as it may come in handy, the other is to remember that VL's are like the VK twin, so you may be able to use some VL EFI bits to help cut costs.
    Good Luck !!!
    Feb 2006
    nz
    Quote Originally Posted by slundy
    well it will be a weekend car and im push towards the 350. just that the 308 is the easier one over all. be im not in for an easy ride
    Feb 2006
    nz
    Quote Originally Posted by Grantis1976
    Good Luck !!!
    the 350 is about the same cost depending were you look and a 350 is sounding a better choice as a storker kit here in nz wood cost more to get the same power as a 350
