hey guys ive got a stock vk commodore and i wont to know if there is any way of removing the air flow unit or repostion it because i wont to put a pod there hopefully you guys can give me some info in doing this thanks for that
cheers
its a 3.3ltr efi black motor?
You cant remove the airflow unit.
You can probably remove the box on the end and place a pod there, i was going to try it till i found out lpg + pod dont mix.
DaZ
Project: Shifty1 commences Feb 2007
The_Monk says:
im a leech
You can remove the AFM from the Airbox as previously mentioned but you will drop perfomance fitting a pod.
The best way to go is to fit a K & N Panel Filter although with a EFI VK the airfilter isnt really a performance restriction.
If you want to remove the AFM completely you will need to fit an aftermarket injection system something like a Haltec E6X.
cheers
Scott
