probably a stupid question, its midnight and i cant be bothered going outside to check, so how do you take out the centre console in a vk? im gonna make a cover for it cause i hate the brown plastic.
cheers.![]()
Scott's VK Berlina site has the info you require, it is very straight forward, just undo the screws then is pops out.
Should be the same as the VL - should effectively be 3 screws in the center console part that hold it to the floor
yep thanks i went out this morning and found out.
