Just finished another engine swap on my mate's VH & was thinking there has to be an easier way.
Is it easier to pull the motor & box out in one go or seperate at the bellhousing & leave the box in the car?
motor and box together i've always found........
I do motor & gearbox together and also I find jacking up the rear end of my car helps as well.
cheers
Scott
yepp definatly the box and engine together![]()
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
That's what I thought, but have had some people say its alot easier to leave the box in the car.....& I will try jacking up the rear next time.....
1234567890
just makes it easier to line the clutch up on the spline i've found.........
Jacking up the rear does work. Just done a VN SS auto & it makes it so easy with the back up, didnt have to tilt the motor at all, even left the manifolds there & they didnt hit a thing.
