hey,
i recently dissmantled my dash to paint it. It turned out to be more difficult then i had anticipated. anyway i did the job and put it back together although it doesn't quite fit the same.all is good now and the paint job looks excellent. however the air con doesn't work at all.
i probably pulled the power or something, can someone please tell be what connections there are for the vk air con thankyou. and what i should look for
Hey man, there should be some vacuum hoses behind your air conditioning panels, you will have to remove the dasd to plug them back in
