Im changing my vk with a 3.3 from auto to manual everything is in except for the peddle box coz i cannot seem to work out witch way the spring goes on to the clutch peddle if any can help me with this it would be good cheers
have a look at the attached picture
any chance of a front on pic instead of side cheers
here you go try this one
that peddle box is way different
Sounds like you have a different pedal box then, cause the pics Scott has posted up are from(looks like it to me) a 6 cylinder Commodore.
yeah well the box n peddle box came out of a vh 202
clutch should be 25.4mm/1" (pivot)
slack should be 10mm-3/8" (pedal travel)
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
thanks for that but i cant get the spring on properly for some reason..to be able to adjust it
