Results 1 to 2 of 2
Thread: Oil pump and timing upgrade.
    85 VK Sedan 3.3 Injected
    Feb 2006
    Christchurch
    Default Oil pump and timing upgrade.
    Looking at getting a JP high volume oil pump and a set of JP helical timing gears for the 202.
    I imagine that the oil pump is a no-brainer, should-do-it upgrade, but is it worth putting the timing gears on??
    Andrew
    -= 86 VK Sedan 3.3 EFI =-
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Unless your pulling big RPM there is no point buying a high volume oil pump the standard will work just fine, timing gear wise JP, TGK doesnt matter what brand as long as you have an Alloy timing gear. If you have a fibre one the time to replace it is either when it strips or when you replace the CAM
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. Bosch 040 Fuel Pump Upgrade
    By muttley383 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2007, 08:01 AM
  3. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  4. timing cover...oil pump
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2006, 10:41 PM
  5. VT 5L: Upgrade fuel pump?
    By klue in forum V8 Development and Modification
    Last Post: 23-05-2005, 07:44 PM
