Results 1 to 19 of 19
Thread: Fuel Cap
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Fuel Cap
    Hey All
    Just wondering if there's is any type of fuel cap out there with a lock that will suit a VC . eg. cap that requires a key
    I don't wanna find out oneday that my car has been milked. eg. fools putting non fuel things in my tank.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    yeah mate, check the wreckers for one, mine came with one standard i'm pretty sure
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Goon
    Hey All
    Yeah mate I got one for my car a few months ago because I didn't want it to get pinched either. The caps are the same from VB-VK. Autobarn sell nice metal ones for $27. It's a twist and push fit. Mine works well. You need CPC part number SL26EC
    Aug 2005
    Queensland
    Goon's Avatar
    Feb 2006
    GC. QLD
    Cheers lads
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    yup, just go in and ask for a locking petrol cap or quote that part number, but also say its a petrol cap. some employees are slow
    VS Commodore Omega
    Apr 2005
    I think they came standard on the upper level cars, I know my old blue VH SL/X had one (not sure if original or not), I'm kicking myself that I didn't save it
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    All Commodores VB-VK had the locking petrol fuel caps Juzza, not just the upper spec ones
    Goon's Avatar
    Feb 2006
    GC. QLD
    Well mine seem to come with your standard turn it and it's off, no lock or key.. One more question before i do go and buy one of these, are they safe ?
    eg. 1 key works with any cap of the same model. ?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    VY Calais, WHII Statesman V8, VC L 202
    Feb 2004
    SE Melbourne
    Quote Originally Posted by SL/ENUT
    Yep, my VC L still has the original one on it. With a bit of work it can be pried off without the key so they're not the greatest, but it's better than having no security. Maybe new repro ones are a tighter fit.
    Goon, if you're so worried about it why don't you install a second-hand cable-operated fuel flap from a VN-VS? Combine that with a lockable cap and your car won't ever be milked.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Cheers again & thanks demon that'll be something to have a look at
    Spike79's Avatar
    Spike79 is offline Just Confused!
    VZ Adventra LX6, VP Berlina LX, Citroen C3
    Bubble Shooter Champion! X-Pipes Champion! Alu`s Revenge Champion!
    Feb 2006
    Brisbane N/W Ferny Hills
    Red face
    I have one exactly the same as the one in the pic Zoist posted which I kept from my old VB. Only problem is i can't use it because i can't fit it in. The LPG filler is just above the Petrol filler behind the petrol flap and doesn't allow any room to rotate the lockable cap.
    Zoist, where's your LPG filler if the lockable cap fits?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Here's mine done on the farm with the MIG welder and a lot of tools. I had to cut the petrol filler pipe in half under the wheel arch and put a flexible petrol hose over it so I could move the petrol filler an inch or so down. Unlike the Ford's, these VK's the pipe is welded into the tank. The end result I am happy with it. I have to take the LPG cap off to take out the petrol cap but that isn't a big deal because I fill up with gas a lot more than petrol.
  15. #15
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Here's a pic of the flap before installing the fillers. We made the plate up from an offcut sheet of steel and shaped it to size. My cousin who is a farmer said that if a gas joint can do this, we can do it!
  16. #16
    Spike79's Avatar
    Feb 2006
    Thanks Zoist. There just isn't enough clearance on mine to get the lockable cap in, with or without the LPG cap on. Thats as far apart as i can get them, can't go any higher or lower with either of them.
  17. #17
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    i have a lockable one but even when its locked you can just twist and pull it off:b:
  18. #18
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Now that above, you would be surprised why that happens. Usually ppl don't push the fuel cap far enough in. On my SL/E i still have the original 1979 one for it, only need one key for the whole car!.
  19. #19
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Yeah you need to push it in pretty hard, until it clicks on both sides.
  1. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  2. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  3. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
  4. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
  5. Steel Fuel Line Into Fuel Rail Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 09:50 PM
