HeyHey
I haven't been on here in soooo long, but anyway I wanted to ask a question about fuel.
I have an 85' VK (black 202, carbied) that used to run on leaded, so now I put in premium unleaded (it pings if I put in normal unleaded) with the fuel additive as well.
Theres this new fuel available at the servo I go to, its 95 octane with 10% ethanol and its really dam cheap. 95 octane is good, but the ethanol? I was wondering if that would do anything bad to an old engine like mine? Or would I use the fuel more quickly so its not worth it anyway? Just wondering if anyone knows anythign about this?
Thanks!!!!
Tara
Say No To Ricers
Hey Tara Your Back!!!
There is nothing wrong with running an ethonol based fuel except dont leave it in the tank for ages as the alcohol will absorb moisture from the air. Also ethonol based fuels have been reported to "root" rubber fuel lines but I am yet to see evidence of that.
A good mod you could do to your car is install a VH dizzy it will allow you to correctly set the timing. Your car should not pink on 98 octane fuel. Using a 98 octane fuel you shouldnt need to run a upper cylinder lube.
Long answer:
Now reasons for running correct octane fuel...
When you run a low or insufficient octane fuel, your engine pinks (detonates, pinking, pings, knock what ever you get the point.) Under load.
Now this causes huge increases of heat in the combustion chamber. Now what this does is causes your exhaust valves to get to point where they begin to melt on the surface. Now generally under high load and/or high-RPM this can/will cause engines to fail.
Now you don’t _have_ to run lead or an upper cylinder lubricant. Under normal every day driving conditions your exhaust valves wont get hot enough (using fuel of sufficient octane) to cause valve seat recession. Even under higher load scenarios this will mostly be the case as well.
I Oz we have had fuels with 98 octane like Shell Optimax and the mobil, BP & Catel Vortex 98 these generally exceed the octane rating for most cars. As you have sufficient octane the car wont pink, because it isn’t pinking you have lower combustion temps so your valves don’t get as hot. As they are not getting, as the valves don’t micro/localise weld themselves to the seats so you don’t get valve seat recession.
note Regular unleaded is around 94 from memory & premium is 96 along with caltex vortex which basically is premium with injector cleaner. Optimax and the other flavours by mobil & BP are pretty much the only true 98 octane fuels.
If you drive an older car like a VB-VK and it is driven in a low-stress application, basically used as a daily driver, then you need have no real need to run upper cylinder lubes or lead. As long as you use a fuel that meets or exceeds the octane rating for your engine. Really the only time you hay require an upper cyl lube is high sustained loads and RPM all the time.
If you rebuild your engine the best way to overcome this from ever happening is to install hardened exhaust valve seat inserts and exhaust valves of harder materials, such as 4N stainless.
Also if you lower your compression this will enable you to run a lower octane fuel. Simply retarding your timing isn’t really the proper way to tune an engine to run a lower octane fuel. Although you can advance your timing when you run a higher octane fuel this is because the cars timing was retarded from factory to pass emissions laws etc.
If your car pinks for a longer period of time you may experience pre-ignition or overrun when you turn your engine off. Basically what’s happening is your cylinder is so hot it’s igniting the fuel without the need for spark. This generally wont last long as your engine will destroy itself pretty quick.
The early commodore engine were designed for 97 octane super. If you run 98 octane fuel you wont need to run an upper cylinder lube. Super used to contain approx .14grams per litre of lead, Potassium, Manganese, Sodium & Phosphorus based upper cylinder lubes wont do the same job as leaded fuels, they burn at a lower temperature than lead does. Although they may aid in protecting they wont do the job as well. Sodium based substitues have been linked to damage to turbo charges.
Most additives will also contain a octane booster component. The higher the octane fuel the cooler the compustion temperature will be.
Scott
As per what Scott said. If you choose the 95 RON blend you're going to run the risk of pinging. The only thing I can correct him on (and this will be the ONLY time he's ever wrong!!) is that regular unleaded is 91 RON.
As for the ethanol blends, like Scott said there's been talk of problems with rubber fuel lines and hence why pre-86 cars are not supposed to use it. Evidence or not, if there's a chance of rubber fuel lines rupturing it's not something I'm willing to be the guinea pig with.
I use Mobil 8000 (98 RON) in my VC only because there's not a BP within cooee of my place. I only do a few hundred km's a year in the car so maybe someone else can answer the next question for me. Naturally I only put fuel in every few months and I've had the latest batch of Mobil 8000 in the tank for about 3 months. Now, I'm told that the shelf life of premium fuels is only 2 weeks. When those fuels go "off" what actually occurs? Do they absorb moisture, or do some of the more volatile hydrocarbons evaporate off leaving a low RON fuel? BTW, even with the old fuel the car still starts and idles fine and there's no pinging happening at the moment. Interested in anyone's thoughts.
Scott + Demons thanks for the replies....
I think I will just stick to the premium + additive (the premium I use is 96 octane) I just dont want to run any risks of damaging my baby![]()
Tara
Say No To Ricers
