Results 1 to 4 of 4
Thread: removing the cam shaft pully
    305holden Guest
    Default removing the cam shaft pully
    removing the cam shaft pully dose it just pull ???? any help would be great
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Cam shaft pully??? What engine are we talking about here??
    If your talking a 202 the cam gear just presses on & off
    the 304/308 is the same as well.
    cheers
    Scott
    305holden Guest
    i got the cam all lose but its not coming out of the block yes talking about the 202 black motor .........everythings out apart from tyhe cam dose it just silde out ????/
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok you need to remove the lifters etc, once you have done that rotate the cam gear and look throught he holes in the gear, in behind you will see 2 phillips head screws remove them and it should come out pretty easy.
    cheers
    Scott
  1. Idler Pully!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2007, 09:02 PM
  2. V6 Idler pully
    By batemada in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2007, 11:45 AM
  3. pully tensioner
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2006, 07:56 PM
  4. Replacing SC14 stock pully with an alternator pully ?
    By gemini in forum General Discussion
    Last Post: 08-05-2006, 04:02 PM
  5. A/C pully..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-03-2006, 12:14 AM
