Results 1 to 3 of 3
Thread: Auto Gearbox.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Auto Gearbox.
    Hey people
    Once again asking a question, what i want to know is if anybody would know the speed ratio for each gear in the trimatic gearbox. 1st - 0 - 60 and 2nd to60 - 80 ?
    Thanks..
    ps. i haven't tested the above yet..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    here you go this is hopefully what your after
    I can do a more specific calculation if you can supply your exact Rim & Tire size as well as diff ratio you can see what I set below. These are the sorts of calculations you do when you want to pic a camshaft for your car so you can see your RPM drop and what power band your cam needs to be in.
    Gear 1 2 3 Final
    Ratios: 2.540 1.600 1.000 3.080
    RPM Limit: 5600
    RPM @Peak Power: 4000
    Tyre Size: 225/65 x 15
    Tyre Diameter: 673.50 mm
    Tyre Circumference: 2115.86 mm
    Gear Km/h per 1000 RPM Km/h @4000 RPM Km/h @5600 RPM
    1 16.23 65 91
    2 25.76 103 144
    3 41.22 165 231
    Km/h RPM (in Gears)
    1 2 3
    10 616 388 243
    20 1232 776 485
    30 1849 1165 728
    40 2465 1553 970
    50 3081 1941 1213
    60 3697 2329 1456
    70 4314 2717 1698
    80 4930 3105 1941
    90 5546 3494 2184
    100 3882 2426
    110 4270 2669
    120 4658 2911
    130 5046 3154
    140 5435 3397
    150 3639
    160 3882
    170 4124
    180 4367
    190 4610
    200 4852
    210 5095
    220 5337
    230 5580
    Gear Change RPM drop (change @4000) RPM drop (change @5600)
    1 -> 2 -1480 (to 2520) -2072 (to 3528)
    2 -> 3 -1500 (to 2500) -2100 (to 3500)
    cheers
    Scott
    Goon's Avatar
    Feb 2006
    GC. QLD
    Cheers Mate
  1. WTB: vl auto gearbox
    By jeddabum in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2007, 09:24 AM
  2. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  3. wtb vr auto gearbox
    By WILD VR CLUBBY in forum Swap / Wanted to Buy / Trade
    Last Post: 12-08-2006, 12:12 PM
  4. auto gearbox
    By alipete in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 09:35 PM
  5. Auto Gearbox for a V8
    By petroleum in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-01-2005, 08:47 AM
