Results 1 to 8 of 8
Thread: 202 dramas!
    Joes_meat Guest
    Default 202 dramas!
    I've just transplanted a VH 202 that I bought off ebay into my VC.
    I finally got her running this afternoon and it doesn't look good.
    White smoke from the rocker cover and somewhere down near the started motor (suspected loose exhause flange bolts.)
    Noisy top end I think - seemed to quiet down a bit when I stuck some more oil in it.
    But the thing thats really worrying me is that it's running off the red side of the temp gague after only 1-2mins of idleing.
    I'm suspecting it's done a head gasket. Is there anything else this could be?
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    Joes_meat Guest
    Seems to have smoothed out and fixed itself with a few starts. Just running on 5 cylinders at idle. Not sure why that is yet...
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Joes_meat
    Pull out the spark plug leads one by one when the engine is running. When you don't hear any difference in the idle then that spark plug needs replacing or cleaning. Spray WD40 inside the leads holes and also on the distributor contacts on the cap.
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
    also if your still having probs with temp gauge take the temp sensor out of the head and check it. It may be clogged up
    Joes_meat Guest
    Quote Originally Posted by ENV5
    It was getting to over halfway just while cranking. Seems to be working okay now but I'll definately clean it anyway. Cheers for that mate.
    All the spark plugs are new, so I'll find the one not firing and re-gap it. Failing that I'll start looking at the dizzy. The points and rotor look pretty poor.
    Thanks for the input guys.
    May 2005
    cool if you can find a electronic dizzy and coil use it i put one on my vb and is alot better
    Attached Thumbnails Attached Thumbnails 202 dramas!-image001.jpg   202 dramas!-dcam0060.jpg
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    If your plugs and leads are ok it could be a burnt valve causing it to missfire at idle. You can check for burnt valves by hooking up a vaccum guage or doing a compression test.
  1. a few vz dramas
    By markovr in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-10-2007, 07:11 PM
  2. VS acceleration dramas.
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2007, 11:31 AM
  3. transmission dramas!!! help
    By lilkel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 08:34 PM
  4. air con dramas
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 12:49 PM
  5. air con dramas!
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2005, 10:18 AM
