Results 1 to 9 of 9
Thread: Wierd VH SLE 308 Blue motor 3 spd
    VH SLE 308
    May 2006
    Question Wierd VH SLE 308 Blue motor 3 spd
    Gday, was wondering if anyone out there can help me. I have some strange issues with my car.
    I have replaced all radiator hoses, thermostat, thermostat housing, belts, viscous fan, cleaned radiator (Tanks off, clean out reseal etc.), Block flush.
    The bloody thing still at times overheats. There is no evidence of head gasket failure, oil is clean, and new coolant. Fan is like a cyclone!!!
    In relation I cannot get the heater to work, The aircon works fine and the interior fan is fairly powerfull.
    Also at times when I pull up and stop the vehicle and turn the engine off you can hear under the bonnet what can best be described as a slowish water hammer. (You know what you sometimes get in your plumbing at home) Very rythmic and slow approx 1 sec intervals then it subsides.
    Is my VH posessed or what?
    Extremely mystified
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    I see you said a block flush, what about the heads flushed out?. Hmmm the radiator fins could be stuffed.
    Ahhh that 'water hammer" sounds like there is air in the cooling. You might need to bleed the air lock out.
    I don't know much about VH SL/E heaters. But i think it somehow works with the air con. I know my VB does.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Could be a water pump problem take your radiator cap off and run your engine to see if you can see the coolant circulating. Sometimes waterpump impellers corrode away so they wont pump
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Does she overheat?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VH SLE 308
    May 2006
    yes it does overheat in summer never got to the stage of blowing hoses or anything but temp guage right up there. Thats another bizarre thing it does. you be cruising along and the temp guage will fairly quickly(30secs) get up to about 3/4, then hold and rapidly decrease(15-20secs) and hover about 1/4 or less.
    foammedia Guest
    vs ute
    May 2006
    does she have a spring in the bottom rad hose as when she gets hot it squeezs tight or i find if you drill about 3 holes in the thermostate helps
    VH SLE 308
    May 2006
    Quote Originally Posted by kyleat1
    thanks for idea. I'll try the holes idea and yes new bottom hose with spring.
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Remove the thermostat.
  1. Doing up a 173 blue motor??
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-07-2010, 08:14 PM
  2. Blue motor into a vk - any issues
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-03-2007, 07:15 PM
  3. 2.8L blue motor, how much??
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2006, 07:15 PM
  4. 2.8L blue motor?
    Last Post: 18-06-2006, 03:16 PM
