Results 1 to 8 of 8
Thread: replacing alternator belt?>
    hocus Guest
    Default replacing alternator belt?>
    is it a pain oin the arse or a 5 min job? i'm no mechenic, lol, but i'm not sure if i'd have to take off every other belt to get it of or if its a "slip over" type task???
    May 2005
    yeh i replaced a belt the other week and had to take air con, alternator and another belt off to get to it. Sorta annoying.
    the lightning
    Jun 2005
    under the Southern Cross
    power steernig and a/c belts have 2 come off, still one of the simpler jobs, belts can be jiggled past the fan if required.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    On a 202 they are a bit of a pain in the arse as they are the rear most belt on the waterpump & crankshaft pully.
    This means you need to remove all of the belts to replace it. You most likely need to R & R your fan shoud, engine fan as well.
    Also its a good idea to disconnect your battery in the process as whe your loosing the nut at the rear you may arc your spanner out on the charge wire.
    cheers
    Scott
    hocus Guest
    Quote Originally Posted by vkberlina
    cheers
    Scott
    yes! i found out about the charge wire, scared the crap out of me! but i go the belt on it wasnt as hard as i thought, i'm glad i didnt have to remove though, that would of sucked! but thanks everyone for your help!
    steve
    May 2005
    oh - I dunno if you've done it yet...but it's a good idea once you've put the new belt on to check it in a few days time. Mine must have started stretching or something and (for some reason we thought the noise was just the air-con belt) eventually it broke...leaving me draining my battery one night...SO had to buy another one!! ugh lol. This one did the same so we had to tighten it a bit more after a few days.
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Just a quick tip.I replace my belts evry few yrs & keep my old ones in the boot 4 emergencies, the same with my radiator & heater hoses.May save you 1 day.
    P.S.I've given my old belts to poor stranded motorists in the past.
    May 2005
    Yeah same - my old one is in there as well!!
  1. HELP!! Replacing alternator and can't get belt back on!
    By VNWagonNZ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2006, 11:29 AM
  2. Adjusting Alternator Belt
    By MILD in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-10-2006, 03:11 PM
  3. Replacing SC14 stock pully with an alternator pully ?
    By gemini in forum General Discussion
    Last Post: 08-05-2006, 04:02 PM
  4. replacing bearings on Drive Belt tensioner Pulley
    By turkeychicken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 01:23 PM
  5. Advice Needed Re: Replacing Alternator
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2005, 03:19 PM
