Results 1 to 17 of 17
Thread: Can a black 202 carby engine be supercharged???
    The 3 Brothers! Guest
    Default Can a black 202 carby engine be supercharged???
    i want to find out if it is possible to supercharge a black 202 carby engine, if so what brands should i look for and where?????
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Same for the blue 202 ?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VS Stato SII L67 S/C V6
    Apr 2004
    yeh but why would you?...you are talking an engine designed over 40 years ago, you are going spend a fortune to get any sort of result from it without it going bang
    you are much better off doing a V6 conversion, or buying a L67 (factory supercharged V6 from the VS-VY), your wallet and sanity will be the real winners, and the thing will go like a rocket
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    May 2005
    TT Supra/HZ Ute.
    Apr 2006
    hocus Guest
    Quote Originally Posted by fentos
    dont mind the look of that, wonder how much it would set you back??? and how long till you blow the side of your block out!
    EF Almost Turbo
    Jun 2005
    nothing wrong with putting an sc14 on a 202, im going to do it when i get a 202 again.. was going to do it to the calais too..
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Yeah it can be done and with some good results, forced induction loves big lazy engines. When you get bored with the draw through SC setup you can move onto a turbo charger. I saw an LJ at the track run 11 sec passes all day with a turbo 202.
    A 202 is a very tough engine if certain pieces are replaced like the timing gear for an alloy one etc. My mate was doing his mechanics course and they got this 202 and tried to blow it up with constant full revs, it took around 45 minutes at full throttle to kill it.
    ========My Statesman 20's Mafless and 3.9's========
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by hocus
    Read the whole thing......
    hocus Guest
    Quote Originally Posted by slundy
    ahhhh, $2000 (pretty much)
    would it be an idea to rebuilt your motor !before installing? alot of 202's have 200000+ km's on them, i know mine does!
    TT Supra/HZ Ute.
    Apr 2006
    You can rebuild 202's cheap. Ive done one with ACL pistons and a few other goodies for just under $2000. It went into my mated torrie and made some good power. till the throttle got stuck and it bent a couple of valves....
    But still you could do it with some low comp pistons and new bearings for nothing at all.
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    VK SL 3.3
    Jan 2009
    Castlemaine Rod Shop has a kit around 1500 but its too small for a 202.
    You could put a 4/71 on it but you would have to get a manifold made for it.
  15. #15
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    Quote Originally Posted by 202_nutt View Post
    when you reply to a post, check that it is still worthwhile by reading the date it was posted in the top left corner of the each post. i think you'll find in this case you have replied to a question asked nearly 3 years ago.
  16. #16
    VK Calais
    Feb 2006
    Quote Originally Posted by VRSS View Post
    would there be a supercharger kit for the 202 EFI's?
    cheers
    CRS are still working on one, but it can be done from thier carbie sc14 kit. All you really need are their brackets ($300) and an sc14 off ebay ($400), the rest you can do in the garage with locally sourced parts. See mine in the rides section.
  17. #17
    VN S1
    Jan 2008
  1. Any problems with V6 supercharged engine?
    By huey67 in forum V6 Development And Modification
    Last Post: 05-12-2009, 10:29 AM
  2. Black VX II Supercharged S pack LOADS OF PHOTOS (My first holden V2)
    By Lloyd1986 in forum VT - VX - VU - WH - V2
    Last Post: 05-01-2007, 10:01 PM
  3. Replies: 32
    Last Post: 07-07-2006, 01:53 PM
  4. Supercharged engine
    By giannetto in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-06-2006, 11:55 AM
  5. My Black Beauty VX Spac Supercharged V6
    By blofly in forum VT - VX - VU - WH - V2
    Last Post: 29-01-2006, 06:55 PM
