Results 1 to 11 of 11
Thread: Ammeter into a VC
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Ammeter into a VC
    Hey All
    I'm kind of stuck on this atm, on location of my horn reley, my ammeter must connect as this piece of paper says for GM. Is the horn reley located in the fuse box area? behind the steering wheel? or near the horn its self?
    Thanks.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VP Exec,honda civic,mazda626
    Jan 2006
    watsonia
    yes i would say so otherwise in the enbine bay maybe near the battery somewhere
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    ok, as far as i know all the relays are in the fuse box. all in a line, have a look on the ORIGINAL fuse box cover and it should tell you what does what.
    From memory the horn is a square relay on the top left whereas the indicators are a cylinder on the top right.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Same place i was thinking dolphin, just wasn't sure.. I'll give it a go anyway.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Well ive been trying to get this thing working a few ways and non seem to work so far.
    Has anybody ever connected one before, one from the auto shops? Or a how to connect the gauge to the horn reley?
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    You don't want to connect the ammeter to the horn relay do you? That would be intermittent.
    Ok. If you want to connect it to say the alternator to see the current, connect one side of the ammeter to the battery +12v and the other side to the alternator output post. But doing this means you have to remove the alternator wire to the battery.
    Remember, to measure current, the current needs to flow through the meter (the same way a multimeter measures current) or it won't work.
    If say you wanted to hook it up to your horn, you would need to cut the wire that comes from your horn relay that goes to the battery and wire the ammeter 'between' the wires so the current flows completely through the meter and not any way bypassed.
    Hope this helps Goon
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks mate, i was hoping somebody would of posted somehing to give me an idea, cheers mate .. I'm stilll working on the dam thing
    But cheers i think it should be sweet from here.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Goon's Avatar
    Feb 2006
    GC. QLD
    This alternator outpost, is the one with the red wires cause that would be postive? there is also a black wire, i have a bosch alternator...
    Well i tried the above to the best description i had in my mind, i connected one wire to the battery and the other at the red wires on the alternator and also removing the wrie from the alternator to the battery and still nothing...
    ps. i had the parklights, cd player and interior lights on.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Goon
    There basically is a post with a wire coming off it and then there is a capacitor connected to another terminal. The ground is the alternator itself i.e: grounded to the chassis.
    The wire coming from the post might not be red but usually is. If your wiring is dodgy, I'd replace that while you are at it.
  1. installing ammeter????
    By crainy in forum Electrical Wiring / Questions
    Last Post: 11-04-2006, 10:03 PM
