Results 1 to 9 of 9
Thread: how to use a multimeter to fix electrical problem on VB?
    VS Commodore Omega
    Apr 2005
    Default how to use a multimeter to fix electrical problem on VB?
    Hi all
    long time reader first time poster lolz, anyway I have a question;
    i have a multimeter and i dont have any idea how to use it! my VB has a electrical problem with the lights not working, and someone told me it can be fixed with the multimeter is this true? Heres a picture of it ive never used one before, so any help or ideas would be wicked-cool
    the problem is the headlihgts dont come on anymore, and only the left side indicator works. someone told me fuses need to be replaced but i need to use a multimeter. theres so many options on it though and i dont know wat is wat or where to plug it into
    thanks in advance
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    To check your fuses you just need to look at them, if they are charred, theyre burnt out, if the metal strip/band is broken, its blown.
    Both means it needs replacing.
    But the indicators should be on a different fuse, this could be a buggered relay or simply loose connections.
    VS Commodore Omega
    Apr 2005
    but the headlights and tails are both broken bro, not just the indicaters do you it could be something dodgy like earthing out or something?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    A common fault is the headlight switch itself. These can burn out. Replace that and see if the head/tailights work.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    you can test 12v stuff mate, by setting it to 20 DCV. top left hand corner if im not mistaken... my meter is abit older.
    I test 12v wires, accessorys, fuses and the battery with that setting.
    testing negtive wires, i usally do this by runniung the metal across a surface until i get a zap i no it's live then
    testing postive wires, red needle on postive wire, black needle on metal surface. anything above 12 is good eg . for a battery mine kicksover at 12.74..
    remember red is postive, black is negtive.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    91 VN SS 355
    Feb 2005
    WEST SUBS
    set scale on Voltage D.C - double rated voltage eg 12 v use 20V scale.
    Make sure you select you meter on Volts Not Amps this will damage the meter or the HRC fuse inside if it is an expensive brand.
    You can also use ur Ohm scale ie resistance to test continuity in a d.c, well impedence in A.C
    I am an Electrican
    Cheers.
    * RVN 355 *
    Goon's Avatar
    Feb 2006
    GC. QLD
    ^^ & that...
    I'm not an electrican i just look, listen, read and learn oh and trial and error until it works
    but ive been around rides allot all my life so u can take my advice if u like..
    VS Commodore Omega
    Apr 2005
    1992 HSV SENATOR 5000i
    Apr 2006
    N/W NSW
    Did you fix the problem? What was it?
  1. Serious Electrical Problem!
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 06:09 PM
  2. electrical problem
    By VL3.0 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-05-2006, 08:31 PM
  3. Electrical problem
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2005, 05:21 PM
  4. Electrical Problem with a VP
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2005, 09:58 PM
  5. Electrical Problem
    By gargs in forum Electrical Wiring / Questions
    Last Post: 02-04-2005, 09:18 PM
