Results 1 to 12 of 12
Thread: Weight of a 253 motor
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Weight of a 253 motor
    Just wondering if anyone knows the approx weight of a 253 motor with heads and the carb on. Oil in sump also. Thanks.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Hmmm 200kgs give or take.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Is that a complete guess? I sort of need to know close to what it is because I need to shift it with a trolley which I don't want to break and haven't got an engine crane. Cheers.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    well some ppl say that the 308 weighs 220kgs. What sort of trolly are you going to sit the 253 on?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Thanks mate. I think I will take what you say... IN
    Basically I am going or planning to use a steel trolley borrowed off a neighbour and it isn't the cheap Bunnings crappy type, it's an old sturdy trolley well made. Then I was going to use a car tyre with it. So basically, put the motor onto the car tyre which is sitting on the trolley and cart it horizontally. I hope that works and nothin' breaks. I thought the motor would be half a ton. If only 200 K's then great.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Yeah that trolly should work fine. Heck moved a 308 once in a rusted out wheel barrow once, it didn't break! That old tyre trick works wonders too.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I did lift a 6 cyl 202 red motor with 2 other blokes once and that was heavy enough!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by SL/ENUT
    Thanks a lot champ. You have given me a lot of confidence now! I was originally planning on moving it in my Dad's mint condition Kelso steel wheelbarrow!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Yeah a guy who had moved a lot of motors said that the tyre trick is always a good way to cart them
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I ended up abandoning the trolley and tyre trick. I thought I might break the neighbours trolley :my:
    Ended up using a trolley jack and wheeling it along. I never thought these things would weigh so much. I'd never do it again without a crane of some sort.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    I was reading my Commodore spec book, says a 308 with everything on it/in it weighs 219kgs. Didn't think a 253 would way that much.
    But its great to hear hat you got the 253 is out.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Heh. All I had to do was take it off a trailer and transport it 15 metres. It felt like a lot more than 200K's. Maybe because the gearbox and oil was in the motor making it heavier.
  1. Weight of VZ or VT?
    By hch in forum General
    Last Post: 23-04-2007, 02:11 AM
  2. vs v6 weight
    By petezor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 10:49 PM
  3. HELP plz.....different weight
    By crazy_wog01 in forum General
    Last Post: 16-11-2006, 09:26 AM
  4. wrx weight?
    By garfa in forum The Pub
    Last Post: 22-03-2006, 10:52 AM
  5. weight of a car?
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2005, 05:59 PM
