Results 1 to 7 of 7
Thread: OMG/............ So much oil!!!!!!!
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    Default OMG/............ So much oil!!!!!!!
    Ok the other day after about a year of saving and waiting i re-built and put in a normal 202 black block with larger pistons and all that.... but when i put it in and started it for the first time there was a huge pool under my car of oil!!!! :b:
    Is this the rear main seal or could it be something else as it has all new gaskets and seals
    This is something that is really frustrating as i dont have a car now what is the quickets way of fixing this???
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I have seen an apprentice before forget to fit the sump plug
    If its dumping a load of oil out fast I would say rear main, timing cover seal/harmonic balencer seal. Or someone forgot to screw int he oil pressure switch.
    as slundy said where is the oil coming from?
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    ok i'll find that out first.... and lol to those apprentice's mistakes
    Oh......... im 99% sure it is coming from the back because the gearbox housing had lots of oil dripping off of it if that helps but when theres time i will take a closer look
    TT Supra/HZ Ute.
    Apr 2006
    Something is not tight or a seal has been put in wrong I would say. Who rebuilt it?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I would say rear main for sure. oculd be the back of the sump gasket if the rubber parts doesnt fit directly into the cork it will leak.
    did you use a rope or rubber seal?
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    found the problem....... after i sent the block to get bored for my pistons, i didnt check all of the back of the block and a plug had been taken out which i thort was still in the block.... lol
    simple mistake, but annoying thanx for the help tho
