Results 1 to 5 of 5
Thread: Gasket job question
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Gasket job question
    Hey all
    I'm catching up on old jobs and what id like to know is when replacing the rovercover gasket, can i take th thermostat off in one whole piece? both top and bottom housing as one. i'm sure it has to come offf to remove the cover.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Yes you can take the thermostat housing off as one piece. But i'm sure that you don't need to take it off.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Nah it looks like i have to remove the housing as i tried before, the ass end will come up but the front wont budge due to be caught on the lower housing.
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    If needed, take the housing off, but replace the gasket before refitting. Get some Permatex RTV 'blue' silicon gasket maker and lather it both sides of the gasket before refitting. It can be picked up at most auto joints.
    the lightning
    Jun 2005
    under the Southern Cross
    Grind a small amount off the back of the upper and lower thermostat housing where the thermostat flange is, that will allow you to get the rocker cover on and off (with a bit of manuevering) in future. make sure you use the little rectangular spacers under the rocker cover bolts on tin ones, they help disperse the load a little more evenly on the rocker cover.
  1. gasket tip
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2010, 09:37 PM
  2. Gasket help asap
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-08-2006, 07:35 PM
  3. Gaskets and Gasket Goo
    By Wacky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2006, 10:55 AM
  4. VRS Gasket Set?
    Last Post: 03-04-2006, 08:02 PM
  5. where do I buy a Full vp v6 gasket kit
    By kowan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2005, 08:11 PM
