Results 1 to 13 of 13
Thread: Rocker ccover oil breather thing - replacement
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Default Rocker ccover oil breather thing - replacement
    Any suggestions on what to replace the rocker cover breather (the one that normally goes to the air filter housing) with? It's on a 202. The normal one has fallen out and isn't a very good fit anyway. We ended up just running without anything in it on the weekend, but need to replace it soon.
    It's a race car so doesnt' matter if it is legal or not.
    ECOTEC KICKED IN yO!!!!!!
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Why not go to the wreakers and pick one up for cheap?
    Autobarn and repco may have them..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    May 2004
    darwin
    we've still got it, but it is an annoying little piece of tubing that goes to the airfilter, and has a habit of falling off
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Replace the grommet. Also get a larger size elbow to fit tight. Mine doesn't fit that well and when I get my new covers, I will relocate it and get new grommets.
    Goon's Avatar
    Feb 2006
    GC. QLD
    I dont have the hose right against the airfilter, do u have the clip thing ? mine keeps the setup in place.
    Your hose may be worn out and to short preheaps
    Off topic VH mate, whats the specs on your ride?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Hey, if its what im thinking it is its a piece of plastic tubing with a right angled bend in it, mine used to fall out as well.
    I was looking for inspiration at found the metal handle on the broom was the perfect diameter tube so now my broom handle is a little shorter.
    I added come small barbs to the tube to help hold it into the rubber hose and it never came off after that.
    Why not run an oil catch can with a breather on that? you would be surprised how much oil it will catch and not get recycled back though the engine.
    cheers
    Scott
    May 2004
    darwin
    Quote Originally Posted by Goon
    pretty much a stock 202. it has extractors, which i think are the ones that were fitted to the VK, as the exhaust diagram in my workshop manual looks exactly like what we pulled off of the car. all it runs now are hte extractors and about 1m of pipe exiting under the passengers door.
    the air filter housing has been modified, the snorkel was cut back so there is a bigger gap. both headlights have been removed so airflow is improved.
    as for the rest of the car, it has been fully stripped, and i mean fully. the only things left are the seat, steering wheel and a patch of carpet under the drivers seat which i haven't got around to removing. as a result, the car sits a good 2 inches higher, and spins the wheels in 2nd at speed. made for excellent fun at the motorkhana i entered yesterday.
    back on topic, the car copped a bit of a flogging yesterday, with no breather hooked up. there was no sign of oil on the underside of the bonnet. what does the breather actually do?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by vh-holden
    Just emmision control. In your case it doesn't matter If you have an exhaust pipe sticking out the side, you might as well remove the air cleaner rocker cover hose.
    VS Commodore Omega
    Apr 2005
    what kind of race car is it and what are you competing in? im facsinated
    May 2004
    darwin
    it is eventually going to be speedway, but i've just gone and caught the motorkhana bug. the car is not set up for any form of motorsport (it isnt' really any good on the street either). If i can find out more about the motorkhana scene up here, i might see about doing that more seriously. It's a killer on the tyres but is physically and mentally demanding.
    we have a long way to go for speedway, they are a bit more strict on the safety aspect of the car. motorkhana being a relatively low speed event doesn't have as strict rules.
    i might even get out and drift it at one of the local meets if i can.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Nice ride mate, must be fun to race her
    If your ever on the north qld coast with that ride let me know, we got similar setups and i wouldnt mine seening her in show
    May 2004
    darwin
    we'll see what the future of racing holds!!!
  1. fuel breather hoses
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2007, 12:38 PM
  2. rocker cover breather moving for Turbo
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2007, 03:06 PM
  3. Breather Cap on VR-VS 3.8lt???
    By Frandy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2006, 10:48 PM
  4. diy crs pcv breather
    By ashzv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2006, 11:07 PM
  5. Breather Hose
    By niggle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-09-2004, 05:57 PM
