Results 1 to 12 of 12
Thread: How to store an engine?
    85 VK Sedan 3.3 Injected
    Feb 2006
    Christchurch
    Default How to store an engine?
    Can anyone suggest the best method / proceedures for putting an engine into storage?
    Looking into my crystal ball I see my VK with a nice and perky 202 rebuilt from a spare engine sourced from a wrecker.
    When it is installed I want to put the current engine in the car into storage.
    Any tips would be great
    Thanks
    AndrewOfNZ
    -= 86 VK Sedan 3.3 EFI =-
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Yeah, basically sit it on a car tyre or use an engine stand. If the carby has been taken off, put a rag in the hole. If the spark plugs are taken out, plug the holes with rags. I have a mate that has had a 351 sitting on the floor of his workshop for years and it would still run fine if put in a new car.
    Oh yeah, rats can't chew through metal so you're safe there.
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Best thing to do is cover with a big plastic bag and spray some rust penitrant in there then seal it. The other thing as slim said is to plug and holes with rags.
    Hope this helps,
    Steve.
    the lightning
    Jun 2005
    under the Southern Cross
    open up the butterfies and tip some oil into the manifold, fire up the motor until it smokes, you'll have to spray CRC rust stopper into eachh sparkplug hole every couple of months, make sure everything is sealed and out of the weather. the bores might rust up very slightly but this will go after a good run, used to have a car sit for 3 weeks at a time while i was interstate and used that trick without any hassles.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Cane_It
    That reminds me of a while back when a guy at the auto shop suggested putting some oil down the carby to try and find an exhaust leak. Man did it blow smoke. I was blowing it for a mile!
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by Slim
    Would have worked though. Not a bad idea.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by slundy
    What I did instead of waiting until the oil hit the combustion chamber, I drove off after giving up after a minute and then I noticed that!
    Mind you, it was an old Sigma, so it doesn't matter.
    Mar 2004
    A mechanic friend told me that when you are going to store a small engine such as a fire pump or generator (that gets used infrequently) he removes the aircleaner and runs the engine at part throttle while pumping an oil can into the carby, until it starts to blow heaps of smoke, then turns the motor off. At the start of every fire season he get people bringing in motors that won't go, it is usually because one of the valves has stuck open, by doing the above procedure the valve surfaces and top rings and bores get coated and protected. I used it on a 3.3 I stored for a couple of years and it worked.
    A good idea when starting an engine that has not been used for a long time, is to remove the spark plugs, ground the coil and then wind the engine over for a fair while after the oil light goes out, ensuring that the crank and cam get some oil on them with no load.
    01 magna exec
    Feb 2006
    gemfields qld
    is it possible for a motor to sease when its just sitting in the car unused for a long period of time? say aprox a year??????
    R.I.P Peter Brock - 26/2/1945 ~ 8/9/2006 - We'll all miss you
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by V3N0M
    Nah man. It probably gets a bit stiff but it would be alright.
    01 magna exec
    Feb 2006
    gemfields qld
    awsome thanks heaps and heaps!! was startin so sheet myself hehe
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Prolly just need a change of fluids and a good run, spray wd40 on the carby linkages too so they don't stick and move nice and easy.
    ========My Statesman 20's Mafless and 3.9's========
  1. Wife Store
    By Ripcell in forum Jokes/Humour
    Last Post: 06-09-2007, 12:29 PM
  2. Husband Store
    By Outlaw Torn in forum Jokes/Humour
    Last Post: 24-06-2006, 11:35 PM
  3. the husband store
    By bazcom in forum Jokes/Humour
    Last Post: 02-05-2006, 06:53 PM
  4. Store Wars
    By Indy_387 in forum Jokes/Humour
    Last Post: 27-05-2005, 08:30 PM
