Results 1 to 4 of 4
Thread: Pod filter
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Default Pod filter
    I bought a pod filter today for my VK (EFI 202)
    I went to put it on and put it all on without the (air flow meter)? or air temp sensor
    Quickly realised that when it wouldnt run.. Then i put the onto the end of the intake pipe, but theres no place for the pod to connect to the air flow meter or temp sensor..
    When i leave the thing off and connect the pod straight to the end of the intake pipe, the car just splutters and conks out as soon as ou start it..
    So i was going to swap the pod for a panel filter and just use that in the stock airbox, but i really want to make a custom box and cold air intake for the pod but need to find a way to connect it to the air thingo..
    Would there be some kind of adapter?
    Mr_Calais's Avatar
    Mr_Calais is offline go the K's
    85 VK Calais and 03 VY storm ute 05 hilux
    Aug 2005
    Yeah im pretty sure that you hav 2 put the air intake sensor onto its own section of piping (just do soming custom) after the air pod. Try taking your car to an exhust center of somthing because they do alot of intercooling piping etc thay could make something up 4 u, shouldnt cost too much. But also make sure you hav sumthing around the air pod to keep as much hot air out as posibile.
    Hope this helps a bit
    85 VK Sedan 3.3 Injected
    Feb 2006
    Christchurch
    Quote Originally Posted by VK_308
    Nothing wrong with putting a panel in teh stock airbox, better than a pod without a cold air box and far easier to do.
    Could go to Repco and get some of that silver expandable / flexi tubing and mount it behind the front bumper going up to the airbox - did that with my Integra.
    Unless your going hi-po you wont notice any diff between panel or pod/CAI.
    I took the airbox out of my coon and fitted a pod and whilst I noticed the diff, it went way better after I put the factory box back in and used a K+N panel filter.
    My 2 cents worth
    AndrewOfNZ
    -= 86 VK Sedan 3.3 EFI =-
    Feb 2006
    Radelaide
    yep went and swapped it for a panel filter today.
    panel comes in on mondayalso bought some PVC piping for a CAI
  1. Filter for CAI
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 11:29 AM
  2. Pod Filter - VK
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-08-2005, 01:45 PM
  3. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
  4. Pod Filter
    By raZel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2005, 10:26 PM
  5. Pod Filter?
    By Shivaga in forum The Pub
    Last Post: 20-07-2005, 01:29 PM
