I haven't got a VC book with me, but have you tried replacing the globe?
Check the wiring diagrams/schematics in the book. I'm afraid you probably won't find any info on it though. The Greg's is pretty limited, but handy sometimes when you want a simple to read answer
The globe has probably just blown. After 28 years of lighting up everytime the car starts, I'd be a bit burnt too if I was a globe.Then again, it might be a miracle and work ok.
Yeah thanks mate, its not a big issue its just something small i noticed.
I'll see how things are working in the morning and if it still does work... i havent payed much attention to it as i always put my seat belt on once i jump in ... It's good to have a mulitmeter its been handy so many times![]()
theres a light for that???.....
Goon, the seatbelt globe only lights up with the other warning lights. Like Craig said it's probably blown. It's not too hard to replace it, just tricky. Remove the 2 screws in the black cluster surround, and I then carefully wedge a thin screwdriver under above the top lip of the surround. It temporarily warps the upper panel just enough to drag inwards the 2 upper corners so that you can maneuver it out of the dashpad. Bob's your uncle from that point on.
gee everytime i have taken a VB/VC dash out, there isn't a globe for the Fastern Seat Belts. There is no spot for one either. I think Holden put them in the dash to fill the spot.
*scratching head until the proverbial light bulb goes on*
I think you're right SL/ENUT, in fact I know you're right. I know all other lights aside from the park brake go out when the car starts but now that you mention it, I have an inkling in the back of my head of seeing this when I replaced the dash globes last (it was 10 years ago I last had the cluster out). Everyone feel free to give me professional doofleberry reputation.
I have a GMH factory wiring schematic for a VC at home I will scan the relevent pages and post when I have it on my site probably tonight.
cheers
Scott
This is a VH dash facia. The fasten seat belt area is in the same spots for VB/VC.
Well behind it, i have maked where the globe should be and guess what...
.... Can't have one there. So i was right. I thought i might of been wrong.
That's funny. You could always do a bit of a mod if you are good with your handsYou could add the globe and use a timer and wire it up to the ignition and have it turn off after 10 seconds say. Gold!
It was an option wen u bought the car new, to have a globe there as well as the trailer light at the bottom. Just about all were neva option with it unless some old bloke or some1 wanted it.
I recall reading in my original owners handbook that it is only ever a reminder - it was never meant to light up. Think about it - to complete the curcuit, there would need to be wiring going from the seatbelt buckles to the dashboard. There is not....
