Results 1 to 14 of 14
Thread: Soldering??
    01 magna exec
    Feb 2006
    gemfields qld
    Question Soldering??
    i need to cut a piece out of the tailgate of my VB due to rust.. was wondering if i made a piece to fit back in there out of some sort of sheet metal if soldering would be good enough?? or do u think it would be better if i just welded it ( i cant weld to well lol ) ut im an awsome solder-er :P..
    R.I.P Peter Brock - 26/2/1945 ~ 8/9/2006 - We'll all miss you
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    Try welding the piece on the inside, then bogging over top (outside) to give the finish.
    VXII S Super6 Manual LPG
    Oct 2004
    Townsville QLD
    VS Stato SII L67 S/C V6
    Apr 2004
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    If you wanted to solder it, you'd be still trying to get the solder to bond on your 85th birthday.
    MIG welding is really the best option. Steel weld. Arc welding will just burn holes in the metal.
    01 magna exec
    Feb 2006
    gemfields qld
    lol thx ^_^
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    What sort of tools do you have?
    A 160 amp MIG can usually weld up to around 6mm and right down to 1mm. Avoid the gasless ones. Try and use gas with the welder as it makes a cleaner weld, but gasless ones with the wire coated can be handy if it's windy but usually makes the weld a bit grubby. Arc welding is best of thicker steel because it's pretty harsh. Soldering is pretty weak because it has 60% tin and 40% lead.
    01 magna exec
    Feb 2006
    gemfields qld
    just the basic ones atm like grinder, sanders and jigsaw. except for the sander im doing a crash corse haha. priced a 100amp mig welder at repco for around $300 ( on special ) not sure how much they are at normal retail price.. ( sux not having money lol )
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Yeah the migs aren't cheap. You'd want to get one that is at least 140 amp I'd say. They would be around $450-$600. Many of them are made in Italy so it should stand up alright. It helps having friends though. My cousin is a farmer and has everything. Heck, he even has a mechanic pit and a 50 or so ton hydraulic press!
    01 magna exec
    Feb 2006
    gemfields qld
    awsome, yeah i dont have a pit or press for that metter lol.. trying to figure out how to get underneath to do all the work needed there....
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by Slim
    All nessasray items on farm. Especialy the press.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Don't forget when using jacks its always good to place car tyers under the car in some places, just incase..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    yeah man i reckon welding it is the way to go, even if you did get the solder to stick, it wouldnt be very strong, if you can get a mig it would probably be easy, i did mine with an arc on low amperage, worked fine, im no engineer or anything, just keeep practising.
  1. soldering a power window module/circuit board
    By rogue_red in forum Electrical Wiring / Questions
    Last Post: 17-10-2007, 05:49 PM
  2. Soldering questions...
    By DANNY8 in forum Electrical Wiring / Questions
    Last Post: 21-09-2007, 09:16 PM
  3. soldering iron and wire stripper.
    By garfa in forum Car Audio
    Last Post: 13-09-2006, 10:09 PM
