hey guys... i need to get a new clutch and a new starter for 85 vk with a black 202 non efi...
just wondering what part numbers.. what works, what doesnt...what i need what dont i need...
i also have a redline roadmaster manifold for my 350 holley to sit on.. what will i need in the way of gaskets and fittings etc to make the conversion??
any help would be great....go the socceroooooos!!!!!!!!!!!!!!!!!!!!!!
Starter motor - definitely the newer small body types much easier tofit and more powerful than the original ones so it will turn the motor over easier.
Clutch, if you want a standard clutch something like a PBR (brand) will be just fine, fit you want a heavy duty if oyu have more power or are towing check out the heavy duty Daiken Exeedy clutches. I had one in my VK and never had any slipping problems I was very happy with it.
Gasket wise, inlet & exhaust manifold gasket, carbie gasket, that should be about it.
