basically i've got a set of ef-el thermo fans and i'm wanting to put into my vk..
i know there's abit of cutting to fit involved but i need help with the wiring side so if any1 has done this successfully please gimmie some info.... cheers
I'll be doing something similar in the same timeframe, AU fans into a 308 vk. will post a full article on it once i have it successfully up and running
yep..planning on taking out manual fan and using them as main
will putting the thermo in the front make any diff or will they work better in bay
you'll have mmuch more room in the bay, make sure the airflows the correct way, ie toward the engine.. shrouding increases cooling efficiency by makeing sure al the air is sucked through the radiator.
If you remove the manual fan, you'll rpm will increase a bit, allot quicker
The way i see it is, aslongas you got air blowing throw your radiator things should be sweet, thoguh remeber thermos cool down a different ay then the old manual fan.
I have mine planned to be mounted on the front for those hot days in traffic and maybe when i wanna take it to the extreme![]()
whattabout aircon condenser would there still be enough room or would i have to sacifice cool air which wont be coz it aint in yet anyway....
