Results 1 to 24 of 24
Thread: 85 kn 16 yr old
    16 vk boy Guest
    Default 85 kn 16 yr old
    hey im new to the game and own a vk 85 modle with just a k and n filter and a holley carby are there many small mods u can do to these cars with big results any replys would be gr8
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Take a look around mate :cool2:
    If you have a mod in mind and your not to sure or whatever, just ask
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    EF Almost Turbo
    Jun 2005
    6 or an 8?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    16 vk boy Guest
    Default re
    Quote Originally Posted by whitevc
    6 or an 8?
    its is a 6 and how do i tell if it is blak or blue or wat
    Goon's Avatar
    Feb 2006
    GC. QLD
    The colour mate but in your case im guessing shes black
    I'm sure on the blacks just like the blues, the engine L is on the bottom left of the engine block.
    have a photo bro ?
    16 vk boy Guest
    no sorry but thank u for your help also i have 2 15inch subs atached to the bak seat as it neva gets used i want to take the seat out so it isnt muffled by the seat i herd there is a hook to get it off is this rite
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I wouldn't recommend you take the back seat out, but... The bottom seat, put your hands through the crack where the seat belt locks are and tilt the seat toward the front. As for the back, put your hands in the same place and tilt toward the front and lift it up & out so it releases from both hooks on the rear frame.
    2 15 inch subs would make you completely deaf by your 21st birthday wouldn't it?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Quote Originally Posted by 16 vk boy
    Also if you change the seating capacity of the vehicle by removing the back seat you will need to get an engineers certificate as well as ADR approval and check with your RTA as well.
    What state do you live in? You might have hassles with the holley when roadworthy time comes around too due to the fact that a holley has no pollution gear or emmisions controls and these things need to be there and functioning properly. The varajet is a good carby and probably a better performer and easier to tune than a holley.
    EDIT: whoops its a 5 litre on gas Holley is a necessary evil LOL
    ========My Statesman 20's Mafless and 3.9's========
    big_c_43 Guest
    [QUOTE=Goon]The colour mate but in your case im guessing shes black
    All of the VKs are black motors. I have a 202 EFI i know it is a black motor but i cant tell from the colour because the manafolds on the EFIs are painted red.
    16 vk boy Guest
    thanks every one for ur help i pulled the seat off this mornin and from all my wireing and stuff i think it looks alot more presentable with it on thanks guys
    16 vk boy Guest
    some one just told me a gud mod is bigger ignition leads is this even a mod is it good wat dose it do were can i get them from
    EF Almost Turbo
    Jun 2005
    your leads can be picked up from any car care shop such as Autobarn and Super Cheap..if its a 6 then there are a few mods.. depends on ya budget..
    DaZ
    The_Monk says:
    im a leech
    the lightning
    Jun 2005
    under the Southern Cross
    extractors are a good starting point, easiest noticeable upgrade on a stock motor, let the thing breathe.
    16 vk boy Guest
    wat size leads would be good for my vk
    can u put any leads on any car and is ngk better than boch or same or other way round
  15. #15
    16 vk boy Guest
  16. #16
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    A set of Top Gun ignition leads will set you back about 30 bucks. Go into Autobarn and tell them what you want.
  17. #17
    MaN|aC's Avatar
    MaN|aC is offline Donating Member
    VT 4.2 S/C
    Apr 2006
    my advice for you is to buy one of these service manuals if you don't already
    http://cgi.ebay.com.au/Holden-Commod...QQcmdZViewItem
    first off buying any old car replace the the spark plugs, leads, air filter, change the engine oil and a oil filter, fuel filter and fuel pump. Buy all of these parts and the service manual shows you what to do.
    208rwkw 13.5 @ 102MPH
    STROKED AND BLOWN
  18. #18
    16 vk boy Guest
    Default thnx
    [QUOTE=MaN|aC]my advice for you is to buy one of these service manuals if you don't already
    thnxk i will buy one i did a service and tune today and its running a hole lot better can i have bosch leads on ngk spark plugs dose it matter
  19. #19
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    No it doesn't matter.
  20. #20
    16 vk boy Guest
    Default lala
    Quote Originally Posted by Slim
    thnx just wanted to make sure be for i started
  21. #21
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    But you do need to have the correct ignition coil to drive your distributor
  22. #22
    16 vk boy Guest
    Default confused
    please explain this wats the ignition ciol
  23. #23
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    It's the can type thing on the lower right hand side of your motor next to the distributor. It has one of the ignition leads coming out of it. It gives you the spark.
  24. #24
    16 vk boy Guest
    thnx i wonder wat it was for
